1982 Corvette Problem
Old Sep 6, 2006 | 11:48 AM
dave61259's Avatar
dave61259
6th Gear
Default 1982 Corvette Problem
To whoever can help,
This is my first time using this forum and I'm not sure how it works but here goes:
I recently purchased a 1982 corvette and I replaced the power window motors. After doing so, I opened the passenger door and the factory alarm activated. According to the owner’s manual, all I have to do is unlock one of the doors using the door key and the alarm should de-activate. Unfortunately, that’s not working and I have not been able to drive my car for a week+ because the starter solenoid has been disabled by the alarm system and I can't get it to reset. Do you have any suggestions????? Help
Dave in TN
Old Sep 6, 2006 | 11:55 AM
SIXFOOTER's Avatar
SIXFOOTER
did you look to make sure the door lock alarm switches are connected?
Might have pulled loose when you were working on it
Old Sep 6, 2006 | 12:00 PM
wnmech's Avatar
wnmech
If its like my 77 it is controlled by a switch on the inside of the drivers door panel with wires connected to a switch on the key lock cylinder. Mine doesnt disable the start circuit. Take off the drivers side door panel and you may have to bypass the switch.
Old Sep 6, 2006 | 12:27 PM
moosie982's Avatar
moosie982
Is it factory or aftermarket ? It could make a difference. Good luck,,,Peace,,,Moosie
Old Sep 6, 2006 | 04:26 PM
Toms82's Avatar
Toms82
Hi,
Did you try unlocking both doors with your key? On my 82, the alarm switch in the left door does not work, but the right door switch does. I don't know enough about the door wiring to know if your work on the window motors would effect the alarm wiring.
Good luck,
Tom
Old Sep 6, 2006 | 04:31 PM
bluesilver82's Avatar
bluesilver82
Buy a shop manual for your car. They are well worth the investment. It tells you how to diagnose and fix virtually everything on the car. It will also give you wiring diagrams and show you where everything is located. You can pick them up off ebay or buy them trough parts dealers. If you give me a fax number, I can send you a copy of the wiring diagram out of my 82 shop manual. Just send me a PM.
Old Sep 6, 2006 | 04:34 PM
dave61259's Avatar
dave61259
6th Gear
To those of you that responded:
I had accidentally disconnected the electric door lock, (that doesn't work), but after reconnecting it and unlocking the door with the key, the car finally reset and I'm on the road again.
Thanks for all your input, you were all a great help.
Dave in TN
Old Sep 6, 2006 | 04:37 PM
dave61259's Avatar
dave61259
6th Gear
Dave in TN
Old Sep 6, 2006 | 04:38 PM
dave61259's Avatar
dave61259
6th Gear
Factory....I had accidentally disconnected the electric door lock, (that doesn't work), but after reconnecting it and unlocking the door with the key, the car finally reset and I'm on the road again.
Thanks for all your input, you were a great help.
Dave in TN
Old Sep 6, 2006 | 04:39 PM
dave61259's Avatar
dave61259
6th Gear
Thanks for your help....I had accidentally disconnected the electric door lock, (that doesn't work), but after reconnecting it and unlocking the door with the key, the car finally reset and I'm on the road again.
Dave in TN
dave61259's Avatar
dave61259
6th Gear
Turned out to be the problem...I had accidentally disconnected the electric door lock, (that doesn't work), but after reconnecting it and unlocking the door with the key, the car finally reset and I'm on the road again.
Thanks for all your input, you all a great help.
Dave in TN
Old Sep 6, 2006 | 06:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ok...5 times was a bit excessive.
Old Sep 7, 2006 | 12:31 PM
bluesilver82
Dave in TN
used power door lock actuators are cheap buy a pair. you can get them for around $19 each off ebay. It is nice to have the options working on the car. I have just about repaired most of my options that were not working. The last option in need of fixing is the cruise control on my car. Then its off to do the dreaded paint job.
To 1982 Corvette Problem
