82 alternator over charging
Old Sep 7, 2006 | 09:22 AM
33Chevy's Avatar
33Chevy
Default 82 alternator over charging
Just completed a long move to upstate NY (many trips). Had my 82 Vette in my barn and on a battery maintainer charger since last year. Took it out this week and now it's over charging. Before I replace the alternator, is there anything inherent with the Vettes that I should check first? With the battery fully charged the system puts out almost 15volts running.
thanks
Ed
Old Sep 7, 2006 | 09:28 AM
Jim Martley2's Avatar
Jim Martley2
The NORMAL charging range of an alternator is 13.5 to 14.2 volts. With the stock guage it may LOOK like it is 15 + volts. Put a voltmeter on the battery terminals and check it there. My 82 ALWAYS reads close to 15 volts going down the highway.
Old Sep 7, 2006 | 09:34 AM
SIXFOOTER's Avatar
SIXFOOTER
Check at the battery and at the alternator, if its 15 at either place you have a problem. Might be simple as the connector on the side of the alternator is loose, Or reg could be bad.
Bob Onit's Avatar
Bob Onit
I would follow Jims advice
If you believe it's still overcharging then I would secure/clean all connections
Theres not much to a GM alternator
The main failure is the diode trio which can be bought for under $3
Old Sep 7, 2006 | 05:04 PM
Boofers's Avatar
Boofers
and check it at the alternator as well just for fun.
Even if your alternator is running at 15V its not going to hurt anything.
Old Sep 7, 2006 | 05:08 PM
GaryS's Avatar
GaryS
Along with the good advice you have been given, DO NOT REPLACE your alternator if you ever find the need to. Have it rebuilt. A local alternator/starter shop rebuilt a neigbor's 73 alternator in an hour while we stood there. He got a newly rebuilt alternator that was original. On top of that the guy put in a new stator (?) flux capacitor or whatever that bumped his amps up about 50% so he could run aftermarket radio and CD player.
Old Sep 7, 2006 | 05:13 PM
Xakk's Avatar
Xakk
I don't usually worry until I see the gauge pegging out at 18. Then I KNOW there's a problem
Old Sep 7, 2006 | 08:34 PM
33Chevy's Avatar
33Chevy
Thanks for the help...I could smell the battery...that's when I looked at the gauge..then hooked up my digital volt meter. We have a local shop that is user friendly and rebuilds as you watch.
Old Sep 7, 2006 | 09:27 PM
Bob Onit's Avatar
Bob Onit
Originally Posted by 33Chevy
Thanks for the help...I could smell the battery....
Not a good sign.
To 82 alternator over charging
