Steering Wheel Feedback
Old Sep 7, 2006 | 02:46 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Default Steering Wheel Feedback
Just wondering if anyone has an idea where to start looking.
When I make a right hand turn under acceleration, the wheel has a shake in it. It almost feels like a 4x4 with the front hubs locked on dry pavement. Left turns are not a problem, and the car tracks straight down the highway.
If it is a low speed corner or I just let the car roll thru it, the wobble is not as severe, but under acceleration you can really feel the front end trying to hop.
It's a '71 B/B if that matters when you give your opinion.
Thanks for any help!!!
Old Sep 8, 2006 | 03:15 AM
sam74c3's Avatar
sam74c3
How are your ball joints?
Old Sep 8, 2006 | 04:03 AM
WESCH's Avatar
WESCH
Hi
A think that a worn out A-arm bushing can also do this.
Problem is, that due to the enormeous front spring pressure, it is nearly impossible to see any wear in this bushings. You can jack up the car and the spring will always push hard on this bushing, so rocking it by hand does not show up any play.
Putting the car on a rattle plate to check drive train play will show this.
Good luck. Günther
Old Sep 8, 2006 | 07:16 AM
DR.Jay's Avatar
DR.Jay
Originally Posted by WESCH
Hi
rattle plate
Good luck. Günther
What is a rattle plate? Is it a type of alignment machine or something different? I'm just curious.
Old Sep 8, 2006 | 04:01 PM
DIP51's Avatar
DIP51
I will check things out and post my results. Thanks for your input!!!
Old Sep 9, 2006 | 09:09 AM
WESCH's Avatar
WESCH
Hi
Rattle plate..... Sorry, surely not the correct name.
It is a plate where the wheels will stand on and shakes the car heavily in order to find any loose or worn bearings, balljoints or whatever.
Usually, only one wheel at a time is put onto this plate and you feel like being on a roller coaster when you sit in.
This test is part of our bi-yearly governmental car check up .
Günther
To Steering Wheel Feedback
