A-Frame Bushings - Ruber or Poly?
Old Sep 8, 2006 | 11:14 AM
kaiserbud's Avatar
kaiserbud
Default A-Frame Bushings - Ruber or Poly?
I was going to go with Polyurethane A-Frame bushings, but I hear even new technology materials squeak. Is that correct? And is it worth worrying about. Are there ‘real good’ rubber bushings nowadays?
Old Sep 8, 2006 | 11:51 AM
crf311's Avatar
crf311
I would go with the rubber. Now if you are going to do the autocross racing, go with the poly.
Old Sep 8, 2006 | 12:22 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
solid steel.
Old Sep 8, 2006 | 01:06 PM
SIXFOOTER's Avatar
SIXFOOTER
Poly is the cats Azz even if you just like a little spirited curves and turns. Car will corner like its on rails
Old Sep 8, 2006 | 01:20 PM
kaiserbud's Avatar
kaiserbud
I will Autocross from time to time, would prefer the handling - but what about the squeaks? Any brand suggestions? I have a set I bought in 1983 ish and never installed - should I just chunk them? As for rubber - is there quality variances?
Turtle - do the steel ones squeak. AND is there that much of a reduction in the softness of the ride when going poly or steel? Would anyone notice in a 69 BB?
Old Sep 8, 2006 | 01:27 PM
SIXFOOTER's Avatar
SIXFOOTER
I never had any squeeks from my 77 after I did it. The kit I am installing on my 81 now had some lube with it, So I don't expect any squeeks
Old Sep 8, 2006 | 01:34 PM
Wrencher's Avatar
Wrencher
I've had Energy Suspension poly bushings in mine for a while, and as long as you use the lube they provide, you should have no problems. If they get loaded with dirt (think off-road), they squeak like crazy, but that's not an issue with mine I do like the handling compared to rubber, but they do transmit a bit more road feel to the car. Mine has the F-41 suspension, so it rides pretty stiff anyway.
Hans
Old Sep 8, 2006 | 02:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The "squeaking" stories are from people who either can't read the instructions and don't properly grease the poly bushings or are stuck in the 1980s, when they did squeak. Go poly. I had them in my old Talon, switched them over to the new one when I wrecked the first Talon, and they were fine when the engine died in that car. 6-8 years and two cars, they never squeaked and still looked new.
I've had poly sway bar bushings in my 77 for years, and they've never squeaked either.
Old Sep 8, 2006 | 02:45 PM
turtlevette
They don't squeak. Can't tell any difference in ride. Never have to worry about them wearing out.
Old Sep 8, 2006 | 03:21 PM
kaiserbud's Avatar
kaiserbud
Good input.... I like the idea of them not wearing out. Any suggestions on brand name - or can I just hit the Hi Perf shop this weekend and grab a set?
Old Sep 20, 2006 | 11:31 PM
kaiserbud's Avatar
kaiserbud
I ordered a set of Energy Suspension red poly bushings from Jegs yesterday.
Question though.... I had my A-arms powder coated. Should the area where the bushings fit be without paint? If so - I would assume you do not want to sand in there - you would want to use a solvent to remove the powder coating ???
Turtle - if these do not prove satisfactory, then I will go steel
Old Sep 21, 2006 | 12:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You shouldn't need to clean out those bores before installing the outer shells. Use lots of that super-sticky grease on the bushings.
Old Sep 21, 2006 | 01:36 AM
Bob Onit's Avatar
Bob Onit
Is the bushing replacement considered a big job?
Any idea how many hours to replace them?
I have one that is visibly warn on the upper pass side.
Do the springs need to be removed ect: ?
Old Sep 21, 2006 | 03:56 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'd do all of them at the same time. It turns into a pretty big job, you need to pull the a-arms. Might as well change the ball joints while doing it if they haven't been changed for a while.
Old Sep 21, 2006 | 06:35 AM
flynhi's Avatar
flynhi
TurtleVette,
Where did you get the steel bushings and is there a performance improvement when changing from poly to steel bushings?
Old Sep 21, 2006 | 11:25 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old Sep 21, 2006 | 11:39 AM
72LS1Vette's Avatar
72LS1Vette
Bushing replacement can be either easy or hard depending on what you want to do. First, you do have to remove the A-arms. Getting the old rubber bushings out can be done a few ways. Some people drill around the rubber and push it out. Some prefer to torch the rubber out. I used the torch method and it's fun but messy.
If you need to replace the shells you have to remove them and get the new ones pressed in. If you use rubber bushings I think you need to replace the shells also. If you re-use the old shells you can clean them and put in poly bushings.
While you are at it you might consider replacing the ball joints and re-packing the wheel bearings.
Rick B.
To A-Frame Bushings - Ruber or Poly?
Old Sep 21, 2006 | 02:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've used poly on other street cars and never had a problem or a squeak. Handling is much more precise than rubber, and the ride is fine.
Old Sep 21, 2006 | 03:04 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Default b
I replaced mine monday with rubber, original style. $68.00 with lifetime warranty from Advance auto parts. It took me about 3 hours total. Remember to mark your shims and put back in the same place. Alignment should be ok, but better to get it realigned. And yes, check your ball joints, good time if they are not real tight. I did not use a spring compessor, just lowered the a arm with a jack and then pop them back in with a litte help from the 3 ft pry bar. Paul
Old Sep 21, 2006 | 04:08 PM
Bob Onit's Avatar
Bob Onit
Thanks Batman and 72LS1
