ET Streets at the strip
You need to stiffen up the rear and soften up the front suspension (adjustable front shocks) to get more weight transfer. Without enough weight transfer, the tires will only make a little difference..
I'm running ET Street tires in the rear and my best 60' time is 1.466
You will lose a little at the 60' mark because of the wrinkle wall design but USUALLY you'll gain consistency..
Compared to slicks, the ET Streets have a much stiffer sidewall. Actually very close to the stiff sidewall slicks that MT sells.
IF you can hook on the drag radial..they seem to run faster due to less rolling resistance overall.
Was anyone else having trouble? Was track just greasy?
JIM
cardo0
I routinely was running 12-13.5#'s of pressure on my M/T drag slicks with no tubes or screws with no issues. I marked them and never had any movement problems using stock 8" rally's.
JIM
JIM
10 lbs. - too little, tire very flat, high rolling resistance, ballooning on
top end.
12-14 lbs - about the same.
17 lbs. - good traction, rolls better, less balloning.
19 lbs.- best overall, good roll, no ballooning, hook with spinnig.
21 lbs. - too much spin, no hook through first gear.
I'm using the same size tires as my previous drag radials, which after a moderate burn out (even through the water) hooked immediately using 22 lbs. of air.
JIM
JIM
Can't say much yet about tire wear as I only have about 600 miles on them. Great tire.
Mark
Mark
JIM
Don't forget, my vehicle is pretty light!!
