Altinator failed.
Old Sep 9, 2006 | 06:41 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Default Altinator failed.
Comming back from a cruise today and my alt failed. Got a 82 with a standard 70 amp equiped alt i believe. Just wondering what is the best way to go as far as amp output (higher than stock) with the stock wireing? I do have a direct feed to my alt via a crane hi-6 msd box.
Old Sep 9, 2006 | 07:24 PM
BarryK's Avatar
BarryK
lots of high putput alternators availabe from various sources but you can also take your current alternator into a local shop that rebuilds them and if you want they can rebuild it as a higher output unit about as easily as they can rebuild it as stock.
Not sure about where yo live but a local place near me that does alternators and starters usually gets them done in one or two days and the cost is typically lower than the cost of buying a new unit.
Old Sep 9, 2006 | 07:40 PM
carl a's Avatar
carl a
good time to get a chrome one
Old Sep 9, 2006 | 11:44 PM
C3Racing's Avatar
C3Racing
Can i get away with a 100 amp alt? with the stock alt harness and also inhance my headlight to dim issue?
Old Sep 10, 2006 | 01:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A higher-amp alternator won't do much for the headlights. A properly set up relay system will.
Old Sep 10, 2006 | 07:34 PM
BarryK's Avatar
BarryK
a 70 amp alt is fine unless you have added a significant number of items to increase the electrial load on the system and increasing the alternator output isn't going to solve a dim headloght problem. The problem in general is that the way the electrical system is designed and set up.
By using relays to take the load off the system and put it onn dedicated relays can help greatly and will make a much greater improvement that trying to upgrade the alternator.
See here:
http://www.madelectrical.com/electri...adlights.shtml
Old Sep 10, 2006 | 07:42 PM
Durango_Boy's Avatar
Durango_Boy
It would be a great time to install a CS130 or CS144, giving you more available idle amps. A CS130 is almost a direct swap in with minor changes.
Old Sep 10, 2006 | 08:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A CS144 is a nearly direct drop-in, too, if you're still running the V-belt system. You just need to move the tensioning arm to the unused bolt hole on the head next to it's original position on the water pump, put a 1" spacer under it, and grind open the tensioning slot just a touch for the 144's M8 bolt. I've FINALLY got mine all set together properly.
If you're running a serpentine system that was designed for a CS130 you may have to futz with the bracketry a bit to accomodate the 144's 5/8" wider bolt spacing.
Old Sep 10, 2006 | 10:19 PM
Durango_Boy
Changing the pullies is a snap since the shafts are the same, and your old alternator has the pulley and the new alt will have the fan. Use the same retaining lock washer and jam nut. Put the alt in a vise, put a strap wrench around the pulley and use an impact the work off the nut. Usually they just come right off, but teh stuborn ones will be a bit tougher.
Old Sep 11, 2006 | 01:18 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The nut has never been the problem for me. That @#$$%#$ compression ring is.
Old Sep 11, 2006 | 01:53 AM
VETDRMS's Avatar
VETDRMS
My 140 amp CS alternator failed on my two weeks ago in the burnout box, the plastic fan exploded and broke my hood. I saw something fly over my head but I thought it could have been a chunk of rubber. Pulled into the pits and noticed a 3" section of paint missing from my hood......
Next day I measured the pullies, it was only spinning at 20,000RPM!
Old Sep 11, 2006 | 04:55 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The 144 I picked up at the boneyard had a cracked fan. I took a steel fan and disc from a CS130, they look like they'll do the job just fine.
Old Sep 11, 2006 | 09:51 AM
Durango_Boy
Yeah I don't think the metal fan will grenade like the plastic one. Regardless...bummer about that hood. You think you can repair it or are you in the market for a new hood too?
Old Sep 11, 2006 | 10:35 AM
VETDRMS's Avatar
VETDRMS
Durango Boy: Yes, I just plan to get a new hood, looking at the 4" cowl as I need the room.
Old Sep 11, 2006 | 10:38 AM
Durango_Boy
Hmm...makes me wonder what's lurking under that cracked up hood of yours. Could be something...MEAN.
To Altinator failed.
