Traction bars
Old Sep 9, 2006 | 07:38 PM
Highhat's Avatar
Highhat
Default Traction bars
Anyone using the VBP traction bars?
http://www.vbandp.com/detail.aspx?ID=426
Old Sep 9, 2006 | 11:26 PM
Twin_Turbo's Avatar
Twin_Turbo
I think 427 hotrod has it...(home made??)
Old Sep 10, 2006 | 12:51 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No I don't have one. I added some other methods to control mine when I installed the Dana 60 IRS setup.
ML67 has one on his car. Not sure if it's VB..but the same design. They primarily keep diff from moving around under launch. They spread some of the load to the forward crossmember instead of all being on the nose mount.
If you are having wheel hop issues, they usually help. But make sure everything else is tight first. I never used one on mine when I was running stock Vette stuff back there, and did fine without it. I was running in the 10's with it.
But everyone I know who added one liked it and they do seem to help breakage issues too somewhat.
JIM
Old Sep 10, 2006 | 03:59 AM
WESCH's Avatar
WESCH
Hi
It is installed to my 68 BB.
Here is a old pic , it was taken to show Bubba's method of wheel alignement by bending the strut rods.
The front bracket of the traction bar ist welded to the crossmember, the aft bracket bolts to the posi.
Does it do anything, I don't know, but I guess it does eliminate posi twisting completely on acceleration and braking.
Günther
Old Sep 10, 2006 | 08:12 AM
73jst4fun's Avatar
73jst4fun
I have the SSM bar (Southside machine) on my 73. I wouldn't call it a traction bar but a stabilization bar like the VB & P bar so the differential doesn't move. No welding was necessary to install and it's very heavy duty, if you can locate one try Ebay, that's where I found mine....you can see a pic of it on my homepage...
To Traction bars
