If you lighten the engine, there really is no need on a C3 to need to move it back. I've installed alot of aluminum components (ie. heads, water pump, manifold, etc.) and when I weighed my 76, it had a 50/50 weight bias without me in it. I would actually like to have it more like 52/48 to help reduce oversteer.
Of course if your drag racing it, I could see the reasoning.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Adding (or changing to) front weight bias is a poor way to reduce oversteer. Increasing your front roll stiffness (or reducing your rear roll stiffness) will reduce your oversteer.
was thinking of minimal fire wall modifications. I know that this has been done on novas etc. with minimal work. plan on lifting the body in 2 wks...
As an example a 69 camaro with a small block no a/c no power stearing
had 55 percent front 45 percent rear. One of my old rags shows
a 70 LT1 vette no a/c or power stearing 49 percent front 51 rear.
I don't even one to look at what a camaro or novas weight dist.is if it had a big block a/c power stearing it would be to scary to look at. my guess would be
around 58 front 42 rear. hell pickups are around 60 front 40 rear.
I have been playing with the roll stiffness and when I get the time, I am going to investigate improving the camber curves & bump steer issues on the both ends of the car. It's just that with me in the car, it actually is rear end biased (like old Porshes) making it a little tricky when running hard. The last time out at the track (not racing, just having fun), I could see where the rear tires were rolling over a bit even at 40 psi. Maybe after I get all the camber/toe/bump-steer curves figured out, it will handle the way I want.
I figure that once I put A/C back in it (it is a street car), this should bring me back closer to a 50/50 with people in the car. I've also debated about trying to lighten up the rear end a bit more .... just not sure how at this point.
