Torque Converter
Old Sep 10, 2006 | 08:18 PM
JustinD's Avatar
JustinD
Default Torque Converter
What diameter converter would I use in place of the stock one? I'm running around 400 hp and I'll use 3.90-4.11 gears. I'm hoping to use a 2500 stall. Would this be enough or should I go a bit more?
Old Sep 10, 2006 | 08:30 PM
75blackray's Avatar
75blackray
What size motor do you have? Street/strip or pure race? 350s have less low-end torque so its better to have more stall, and bigger cams move your power into higher rpms so they also need more stall. I have a 355 w/ about 400 hp that I want to keep streetable. So, I am going to go w/ a 3000 stall and 3.70. Hope this helps .
Old Sep 10, 2006 | 08:31 PM
JustinD's Avatar
JustinD
It's a 350. Street and the strip rarely just for some fun.
Old Sep 10, 2006 | 08:36 PM
Little Mouse's Avatar
Little Mouse
Maybe a 3000 if your going to street drive, if your going to be a
racer more. With 390, 4.11s 2500 you never get anything for free
with more stall comes more slipage.
C3 Stroker's Avatar
C3 Stroker
The amount of stall would depend on the torque curve of the engine, and how much you could live with on the street.... big or small block?......cam duration, vehicle weight, etc. But generally, 2500 is a good performance stall rpm, and most manufacturers utilize an 11" converter for this.
Old Sep 10, 2006 | 08:37 PM
JustinD's Avatar
JustinD
Well, I'm not gonna do the strip much at all. But I at least want to do it once a year maybe. I think I'll go with a 2500 stall just to keep the tranny temps a little lower.
Old Sep 10, 2006 | 08:39 PM
JustinD's Avatar
JustinD
So something with a 11.5 inch bolt circle will fit? Right?
Old Sep 10, 2006 | 09:02 PM
Little Mouse
Do they make converters that are for the 153 tooth flex plate and
another to fit the 168 flex plate ?? or will one converter fit either
size flexplate ??
Old Sep 10, 2006 | 09:09 PM
C3 Stroker's Avatar
C3 Stroker
size flexplate ??
I know TCI makes dual bolt pattern ones to fit either one....otherwise, check manufacturer's specs as to what fits.
Old Sep 10, 2006 | 09:22 PM
Little Mouse
Justin what size flex plates in your car I would think it would be 168.
Old Sep 10, 2006 | 09:24 PM
JustinD's Avatar
JustinD
Thats a good question, and I have no answer. Maybe someone else knows for sure.
Old Sep 11, 2006 | 04:55 PM
JustinD's Avatar
JustinD
I called Hughes and they said that it will fit my stock flex plate. He also said that I may want to think about going with a 3000 stall. The only problem I have with that is the price really jumps up when I want a little more stall.
To Torque Converter
