clock and printed circuit sheet,1978
Old Sep 10, 2006 | 09:11 PM
Laird1978's Avatar
Laird1978
Default clock and printed circuit sheet,1978
I recently had my center gage console out and noticed the circuit to the clock is burned out. Obviously the clock does not work. What are the odds the clock is ok and just needs the printed circuit replaced? Or did the clock go bad which then burned out the printed circuit?
Old Sep 10, 2006 | 10:52 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
You can repair the circuit board pretty cheap. Just use a low heat solder gun and small wire solder. Chance are that someone removed the dash or gauge panel when it still had power and shorted the connector out. I would check the board at the connector first. Make sure all the stripes are glued down and not crossed.
