Temp sending unit
Old Sep 11, 2006 | 07:44 PM
Tom68's Avatar
Tom68
Default Temp sending unit
I've read here guys talk about finally getting the correct temp sending unit to make their gauge read correctly. My gauge is reading 210 and I just shot the radiator with temp gun it's reading 185. So where do I gewt a correct sending unit. It's a 68 327 car.
Old Sep 11, 2006 | 07:47 PM
cchristo's Avatar
cchristo
Might be wrong, but you will never get the same temp reading if you sample the temp at two distinctly separate locations using two distinctly different sampling methods.
I think that by trying to match the sending unit signal to what is in the radiator is the wrong way to go about it.
Here is the only way I can think of to get a perfectly accurate reading from the temp gauge.......
Pull the sending unit out and leave the wire connected. You would have to use an extension. Then, you would have to figure out how to ground the sensor back to the car. Put a pan of water on a camp stove or something and put the temp sending unit in the water. Put a good thermometer in the water. turn the key to "on". compare the gauge to the thermometer in the pan of water. You might be able to calibrate the sending unit by putting a variable resistor in line.
Unlesss......does anyone know if it's possible to calibrate the gauge itself?
How's that for some bubba fixin'! ?
Old Sep 11, 2006 | 08:05 PM
C3 Stroker's Avatar
C3 Stroker
I've done the resistor deal and was able to get correct readings putting the resistor in line, but a better solution was to buy the correct sending unit which I found available from Clocks by Roger.
Link: www.corvetteclocks.com
Sending unit: http://www.corvetteclocks.com/page12.html
Old Sep 11, 2006 | 09:36 PM
Vettkeeper's Avatar
Vettkeeper
http://www.corvettespecialtiesofmd.com/faq/faq1.html
Great web site, explaines the problem and they have the cure
Old Sep 11, 2006 | 10:39 PM
cchristo's Avatar
cchristo
Wow! Great info. It's always good to learn something new.
I gotta admit though, I thought I actually came up with the resistor idea
Old Sep 12, 2006 | 10:40 AM
pws69's Avatar
pws69
Lectric Limited is the ONLY place I found one that was accurate and had the correct connector.
Old Sep 12, 2006 | 10:44 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree. Their units are properly calibrated to these gauges.
Old Sep 12, 2006 | 11:13 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
Old Sep 12, 2006 | 07:48 PM
Tom68's Avatar
Tom68
Default sending unit
Thanks for the info I'm ordering a sending unit now.
Old Sep 14, 2006 | 11:03 PM
clintwilson's Avatar
clintwilson
Default temp. sending unit
i had the same prob. on my 80.try volunteer vette products. it fixed mine.
Old Sep 15, 2006 | 05:59 PM
carbster09's Avatar
carbster09
Default Corvette clocks unit
I tried one from rogers corvette clocks. It still seems wrong ... I used a heat gun too.... Then again I put it in with some sealant, which I now believe is a no-no; as the unit is not properly grounded. Is this correct?
Old Sep 15, 2006 | 07:26 PM
C3 Stroker's Avatar
C3 Stroker
Too much sealant could cause bad contact, but I tried mine with and without sealant and the readings were the same.
To Temp sending unit
