engine VS chassis DYNO #s?
Old Sep 12, 2006 | 08:29 AM
waterplay's Avatar
waterplay
Default engine VS chassis DYNO #s?
Looking to see what the power loss is going from an engine dyno to a chassis dyno. I thought I read that a vette with the independent rear has more of a loss close to 18%. Additional info…I have a 4spd in the car this should be better than an automatic. Does anyone know what the actual # is?
Old Sep 12, 2006 | 08:47 AM
Tonys96's Avatar
Tonys96
My engine dyno numbers had the engine completely unencumbered by accesories, no alternator, P.S. and an electric water pump.
Subtracting 23 H.P. for alt., P.S. and water pump it was exactly an 18% loss.
'79 with Muncie (not BW) 4-Speed.
Old Sep 12, 2006 | 10:13 AM
waterplay's Avatar
waterplay
Just to make sure that I understand what you said. You lost 18% of your power when you went from an engine dyno to a chassis dyno?
Old Sep 12, 2006 | 12:52 PM
69autoXr's Avatar
69autoXr
Sounds like he is referring to gross vs. net hp ratings at the flywheel, not engine vs. wheel hp.
Old Sep 12, 2006 | 01:21 PM
l88rocket's Avatar
l88rocket
Just about every street car has a 15-18 % loss for manual trans,and 20% for auto.
My 69 427 on the engine dyno made 582,and put 490 to the wheels on a dynojet dyno
Old Sep 12, 2006 | 01:51 PM
Tonys96's Avatar
Tonys96
Yes that is correct. The accesories ate 23 H.P and the transmission and differential ate 18% or 82 H.P.
So overall my rear wheel horsepower was 105 H.P lower than my flywheel horsepower.
Old Sep 12, 2006 | 02:22 PM
waterplay's Avatar
waterplay
18% is what I thought. I am on my way to the Dyno (chassis) on Friday so I wanted to have an estimate of what the eng was making. I hope I have something to brag about Friday afternoon. The main reason for doing the Dyno tune is to make sure that everything is correct and working to its best.
Old Sep 12, 2006 | 03:55 PM
commando57's Avatar
commando57
WHERE??
Old Sep 13, 2006 | 07:33 AM
waterplay's Avatar
waterplay
Originally Posted by commando57
WHERE??
HP Works in Colonial Beach
Old Sep 13, 2006 | 09:15 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
You loose about 12% - 15% with a manual transmission and 20 - 25% with automatic. High Stall converters will cost you even more than that. Add another 5 - 12 % accessory loss IF the engine dyno run was done without mufflers and accessories. If the engine dyno run was done with all the accessories, the drivetrain loss should only be like stated in the top of this post.
To engine VS chassis DYNO #s?
