Wheel adapters sizing
Old Sep 12, 2006 | 02:47 PM
Kalway's Avatar
Kalway
Default Wheel adapters sizing
I'm looking in to rims, still, and am sorta lost on what size wheel adapters are required to fit different rims. After seeing the thread on the C4 sawblades on a C3 I decided to see how much those rims and tires would cost and it was less than half of what new TTIIs and tires would cost.
So basically the question is what size adapters would I need to fit later model Corvette rims? Preferrably the 17" ones.
Old Sep 12, 2006 | 04:47 PM
vetteaddic's Avatar
vetteaddic
[IMG][/IMG]
Im running 17x9.5 wheels with 7" backspace and a 2.25 think adapter(spacer)
Old Sep 12, 2006 | 04:53 PM
Kalway's Avatar
Kalway
Those are the C5 rims right? What size tire are you using with them and how accurate is your speedometer with them? Did you have to flare the fenders to make them look right?
Old Sep 12, 2006 | 06:11 PM
vetteaddic's Avatar
vetteaddic
[IMG][/IMG]They are off a 98 SS Camaro 275 40 17 on the back and 245 45 17 up front,no flares ,the fronts did rub the frame a tad when I ran 275 up front but if I got a thicker spacer 2.50" it would fix that,
I've been running this set up for 5 yrs with no problems.
,also installed 17x11 with 315 35 17 on the back to see if it would work and had to remove rear swaybar, heres a pic.speedo says about 5 to 10 mph faster
To Wheel adapters sizing
