I want to upgrade Corvette's stock 350 & TH350. I want gobs of torque and plenty of 4000+ RPM HP. I would like to stay in the small block package. Without going to an LS1 swap, what are some good tried ideas?
Block
I'm building a solid 400, just like a lot of people here. Also like others I'm toying with various FI options but in the start up. I'm gonna use a manifold and carb. The HP and torque from a bored 400 is more than enough to break loose your stock tires and will out perform your stock suspension.
A big block would put a lot more weight at the nose of the car and un-balance it for even worse handleing. Stick with a small block unless you want to modify the suspension and breaks too.
If money is in your wallet, you could buy a crate, a nice FI system, and utilize pre-fab glory.
You have a lot of choices, it just depends on your budget and you'r over-all goal.
Damn that's sweet,I totally forgot about putting a carb on one.Looks real good
YEAH after worked a few bugs out... I have had a few different techs say I should be all over the high 12's.
Best part is... MSD makes a new box with a step retard for NO2 so... I will put grade to that... and shoot for low 11's with a 175hp cheater system I already have...
With the new box you can tune it with a hand plug unit or run it through your home computer to set fuel map and retard... they say it is really easy to adjust...
Here's a book that I picked up recently. It's definately worth picking up if you're like me and have never attempted a project like this. Lots of good info. I have a buddy that just dropped a 454 BB into his 75 Camaro and now I have the bug too. I'd like to stay with a SB though. They have several engine buildups in the back of the book that are pretty interesting. Everything from 383 on up to a 454. They had a 406 that made 525 ft/lbs and something like 450hp. That was I was leaning towards but I've heard a lot of horror stories about the siamese 400 block. Everyone keeps telling me to go with a 383. At least that way you can use your existing block. Good luck with the hunt!
-CR
I'm curious as to how well a bored out 350 will hold up as a 400. The cylinder walls must be extremely thin, and I would suspect cracking to be a major issue down the road somewhere. I can't see this motor last very long is used fairly hard often. Or, is there a way around this?
gkull, and inch is an inch on 23* heads but the LS stuff makes insane power with it's altered valve angles. If you ran 18* or even 12* heads, etc. on your smallblock, you'd probably be able to hang with 'em. I agree, the big-inch big block stuff makes a lot of grunt, too - that's why I picked 'em for my current builds. Once you get to 18* (or even lower) valve angles on the big stuff with Big Duke/Big Chief heads, you're talking well over 1000hp on a 565 cubic inch engine. Trouble with 'em is the offset lifters and crazy pushrod angles, they don't make for street friendly engines. I'm building two conventional headed big blocks now - a hydraulic roller cammed 565 that I'm looking to make 750 or hp with and a solid roller 499 (3.75 x 4.600) that'll make the same hp numbers, just at a higher rpm and with less torque. I have a CNC Bowtie big block that I'm saving for a future procharger build as soon as I gather the big pile of cash it'll take to get that done.
If I were trying to build a smallblock with a lot of grunt and do it on a budget, I'd probably go with a 406 with some good heads and a healthy hydraulic roller cam (just for less hassle with maintenance).
-CR
Thanks Rich. I went out to Border's last night and bought it.
