1979 doorlock removal
Old Sep 13, 2006 | 10:11 AM
dmoff1's Avatar
dmoff1
7th Gear
Default 1979 doorlock removal
I have removed my driverside glass and hardware so I can replace the electric window gear. while I'm in there I want to take out my door lock so I can get the number off of it tohave a key made. I have removed the outer clip and unplugged the 2 pronged wire. ther is still another wire connected to the door lock how do I finish removing the door lock? Lord knows I don't want to break anything in that tight little space. any help is appreciated
Old Sep 13, 2006 | 12:40 PM
C3 4ME's Avatar
C3 4ME
I'm not sure I follow you on the outer clip you mention, but there is a horseshoe shaped clip on the inside of the door that holds the lock cylinder in place. I was able to get a flat blade screwdriver in there an push the clip off. I recently removed my locks when my car was painted and I have a 79 with power locks. BTW, I'm sure you also know you have to remove the rods that active the lock mechanism.
Old Sep 13, 2006 | 03:41 PM
dmoff1's Avatar
dmoff1
7th Gear
got them out. there is no number on either of them,so I am trying to get a key made manually
To 1979 doorlock removal
