Battery cutoff switch antitheft
Old Sep 13, 2006 | 06:57 PM
68 NJConv 454's Avatar
68 NJConv 454
Default Battery cutoff switch antitheft
I'm trying to design a security feature on my 68.
I'd like to install a battery cutoff switch that I can disconnect and remove the key.
Will this one work....
180 Amp Keyed Main Battery Switch
Sealed battery disconnect switch is rated for 180 amps continous, and 1000 amps in-rush. Suitable for electrical systems ranging from 6 volts to 36 volts. One piece die cast housing is 2 5/8" in diameter and 4 1/8" long. Mounting stem is 3/4" in diameter and 25/32" long. Single Pole (on - off), Single throw wiring terminals are 3/8" studs. Switch is key operated.
A friend is arguing that it should be close to 500 amps continous b/c what if its a cold day and it takes you 20 seconds to start your car instead of the usual 2 second spike of major voltage to the starter.
If this will not work, does anyone have any suggestions?? Must be able to remove the switch like a key.
Found the above on www.wiringproducts.com Select "Switches, Relays, Flashers" on left menu then "Battery Disconnect Switches" then second from top. Neat site.
Old Sep 13, 2006 | 07:03 PM
...Roger...'s Avatar
...Roger...
I have the Battery Master(red removable handle) on my RV no problems.edit-its the one in the pic just below yours at that site-my 454 when hot after coming off highway turns over hard-I start it with both batterys through the shutoff-your switch has better specs.
Old Sep 13, 2006 | 07:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Do you have an MSD ignition ?
Old Sep 13, 2006 | 08:31 PM
68 NJConv 454
Not at this point...haven't gotten to the engine & ignition part of the restoration. Was thinking about it.
How would that change/benefit things? just add it to the parts needed list
Old Sep 13, 2006 | 08:50 PM
MotorHead's Avatar
MotorHead
MSD ingnition has a anti theft deterrant, you ground a wire that comes off it and you can't start it. You just hide the switch, that's what I did, I feel fairly safe with it, I don't leave the car anywhere for extended periods of time though. That is what you had in mind for a battery cutoff ?
Old Sep 14, 2006 | 06:45 AM
Bob Onit's Avatar
Bob Onit
Thanks MotorHead, good to know
Im guessing this can be adapted to any ignition as long as it doesnt interfere with the output.
Old Sep 14, 2006 | 10:26 AM
68 NJConv 454
Ever see the movie Gone in 60 Seconds??
No car is safe hehe.
I just wanted an extra step to make me feel safe aside from removing the battery from the car if I keep it in my "garage" or park it at work for the day.
If someone wants my car then they'll get it one way or another, but I'd like to make it as difficult as possible!
Now how do you block a flatbed??
Will that stitch I have listed in my first post be alright for my purpose or do I need a higher amp one? thats the highest I've yet to find.
Thanks guys
Old Sep 14, 2006 | 12:21 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Thanks guys
Tear gas nozzles rigged to a motion sensor?
Old Sep 14, 2006 | 01:26 PM
gkull's Avatar
gkull
Probably about a year ago i installed (don't laugh) a removable key battery diconnect switch from "JCWhitney" I did a post on it.
For racing safety reasons i installed a battery cutoff switch that i can reach to in case of a fire or crash.
It also solved my battery drain during prolonged sitting and it's a perfect antitheft device.
Old Sep 14, 2006 | 04:02 PM
68 NJConv 454
I bought the same (JC Whitney) one at Carlisle but its not rated very high. It has the removable red handle.
I found the one above which actually has a key & tumbler for the battery disconnect. Thats what I want to install.
GKULL, found this thread. Which one did you end up using?
http://forums.corvetteforum.com/showthread.php?t=772833
http://www.jcwhitney.com/autoparts/P...+master+switch
Old Sep 14, 2006 | 04:47 PM
gkull's Avatar
gkull
I have the red key 500 amp unit and it's never had a problem. I have a 900 or 950 CCA battery and it just zings my high amp mini starter. I just cut my big Pos battery cable going to the starter and soldered on big lugs.
My 79 has the 3 lid storage boxes. (battery - small center - tool box) I cut the battery cable in the middle box and mounted the switch so I can reach it even strapped in my 5 point. Right between the seats on the rear of the console
Old Sep 14, 2006 | 05:08 PM
68 NJConv 454
Exactly where I was thinking of mounting mine. Very easy routing of the positive wire since its already going down the trans tunnel.
If its not a lot of trouble, I'd love to see how it looks in that location.
If you have any pics please post or send to doogie1101@hotmail.com
Thanks GKull.
Old Sep 15, 2006 | 02:36 AM
Bob Onit's Avatar
Bob Onit
I doubt it
It was a one star movie at best
Old Sep 15, 2006 | 04:55 AM
PRNDL's Avatar
PRNDL
Wouldn't a battery cutoff switch mounted near the battery be very easy to bypass? I use one of those silly green plastic wheels, and when you are disconnecting the battery you can turn the wheel until it comes completely off and take it with you.
Old Sep 15, 2006 | 07:04 AM
Blue Juice's Avatar
Blue Juice
Default Theft deterant
If your main reason behind this is theft deterant, I would suggest that you leave the battery alone and instead put a hidden switch that interupts or grounds the ignition circuit.
This is mutch easier to hide, and can be used with a key switch for added security.
If some rascal tries to steal your car and the engine won't even turn over, they will look for a battery isolator, and there's not too many places they can go (also quite esy to trace battery cables).
If instead the engine turns over but fails to start, then they are more likely to keep trying to start it (pumping the gas, pulling the choke out, keeping the gas pedal down etc.). The battery will flaten and the car doesn't get nicked!
That's how I have always secured my cars, and (touch wood) I've never lost one!
Removing rotor arms etc is always an option, but I got fed up with that hassle years ago...
Just my tuppence-worth,
Douglas.
Old Sep 15, 2006 | 08:19 AM
shafrs3's Avatar
shafrs3
I use one of these and it works well.
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 15, 2006 | 08:42 AM
norvalwilhelm's Avatar
norvalwilhelm
Douglas.
I agree. If the starter doesn't turn over it gives them a clue what to look for. I have a hidden KEYED switch that has to be bypassed in a certain way that allows the motor to start. Without this bypass the motor starts, runs fine for about 100 yards and then comes to a stop, not to restart again until reset.
To Battery cutoff switch antitheft
Old Sep 15, 2006 | 10:10 AM
noonie's Avatar
noonie
You can also put an elec valve in the fuel line with a hidden switch. Will run till the carb empties.
Old Sep 15, 2006 | 11:14 AM
Bob Onit's Avatar
Bob Onit
We had this same discussion a few weeks ago
If you want a heavy duty cutoff switch here ir is
http://www.spectorracing.com/catalog..._terminal.html
Old Sep 15, 2006 | 11:40 AM
pmazza's Avatar
pmazza
Flaming River has some nice HD cutoffs - one of the deterrents I have installed is the removable key unit:
http://www.flamingriver.com/index.cf...prod/prd66.htm
Phil
