Qjet question
Old Sep 14, 2006 | 06:58 AM
bradzap's Avatar
bradzap
Default Qjet question
Aright, guys I have a quick question.
After a long cool down (more than a day), it takes awhile to get the engine fired. I looked at the accelerator pump, and I get 2 pumps before the bowl is dry. Is that normal or do I need to re-epoxy the machine ports in the bottom.
Thanks for the responses. It always surprises me, the wealth of knowledge on this forum
Old Sep 14, 2006 | 07:27 AM
Bob Onit's Avatar
Bob Onit
Sounds like your well plugs could be leaking
Read Lars paper on how to repair them correctly... Lars suggests a drill/tap/plug method
Many use epoxy... with good results so it's your call.
I am still not sure if a mechanical fuel pump has a check valve or not, there was a pretty long thread about this not long ago but I dont think anybody came up with a definitave answer...
Old Sep 14, 2006 | 10:48 AM
olescarb's Avatar
olescarb
your problem is most likely the fuel evaporating/boiling out of the carb after the engine is shut off. some of the gasoline just sitting in a cup at room temprature would evaporate out of the cup, so add in the high temps under the hood and you can see why this happens. try opening the hood and leave it open after you shut the engine off to let the heat out and see if you still have the problem.
henry @ oles carb
Old Sep 14, 2006 | 02:04 PM
TJ76's Avatar
TJ76
Or you can just start it for a second or two to fill the bowl and shut it off right away, the bowl will be full with no heat soak. Then wait a day or two and see if it is still empty. I highly doubt it will evaporate that fast. Mine will sit all winter, and fire-up without a cough. Sounds like classic well plug leakage. Good luck.
TJ
Old Sep 14, 2006 | 09:39 PM
CF6873's Avatar
CF6873
I have epoxied mine and I don't think they leak but I need to pump the throttle 10-15 times to get it to fire up. It also smells of gas shortly after shutting it off.
Old Sep 14, 2006 | 09:59 PM
greyghost79's Avatar
greyghost79
i have the same problem with my 79 (L82). fuel bowl goes dry after sitting several hours. then must crank and pump like crazy to get it started. would leaking well plugs make the engine idle poorly on cold startup? that's the only real problem i have with my Q-Jet. thanks for any info.
Old Sep 14, 2006 | 10:37 PM
Bob Onit's Avatar
Bob Onit
Thats it!
Quadrajets suck............. Im going with the Holley again
Old Sep 14, 2006 | 10:58 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Originally Posted by Bob Onit
Thats it!
good luck with that........
Old Sep 15, 2006 | 02:28 AM
Bob Onit's Avatar
Bob Onit
Hey .... can you blame me?
I have to go with the majority....
Old Sep 15, 2006 | 07:00 AM
bradzap's Avatar
bradzap
Thanks for the info.
The carb works great and I use MUCH less fuel than my buddies with the Holleys.
I'm pulling the carb this weekend and will re epoxy the well plugs. I'll let you if that works.
Old Sep 15, 2006 | 09:40 AM
sly vette's Avatar
sly vette
If you have a paper filter in the carb try going to one with a check valve in it.
Old Sep 16, 2006 | 08:31 PM
Bob Onit's Avatar
Bob Onit
Check valve in a filter?
That would be great
Do you have a part number?
Old Sep 16, 2006 | 11:12 PM
SmokinBBC's Avatar
SmokinBBC
Did you dump all those q-jets you were collecting?
Old Sep 16, 2006 | 11:55 PM
vettepilot68's Avatar
vettepilot68
Before you epoxy the well plugs you might want to replace your gas cap and see if the problem goes away...if you have a vented cap. Sounds silly but I just went through the same issue you are dealing with. I couldnt believe it, but it worked. Of course this is assuming you have your return line hooked up as well.
Old Sep 17, 2006 | 02:54 AM
Bob Onit's Avatar
Bob Onit
No way!
I have rebuilt a few and either gave them to friends or sold them
I have collected a few more in their place
Old Sep 17, 2006 | 03:28 AM
Kalway's Avatar
Kalway
No way!
So when are you going to make one for me?
Old Sep 17, 2006 | 04:51 AM
Bob Onit's Avatar
Bob Onit
As soon as you figure out what the hell you want
To Qjet question
Old Sep 17, 2006 | 09:35 AM
sly vette's Avatar
sly vette
That would be great
They have made them for years,Bob.
Sorry I do not have a part number but I have a spare filter if you would like me to send it to you.
Send me your address.
Old Sep 17, 2006 | 01:57 PM
Bob Onit's Avatar
Bob Onit
Thanks for the offer Sly
I was just trying to find a way to diagnose some of the members problems with leaking fuel back after they have been sitting for a day or so
I could swear that some older Chevrolet fuel pumps had a check valve but I guess it may not be true.
A filter with a check valve could solve this mystery.
Old Sep 17, 2006 | 03:13 PM
greyghost79
where can you buy such a filter? never seen one advertised.
