engine rpm drops with brake
Old Dec 30, 2006 | 01:43 PM
  #41
happiedazs's Avatar
happiedazs
You say that with the car in neutral and ideling, when you pull off the vacuum advance hose the engine quits. This sounds like a carbuerator problem and/or a fuel mixture problem.
First, the mixture is too lean --- back out each of the two carb screws in the front of the carb two full turns. Then get some gumout (or any carbuerator cleaner) and run it through the carb as close to full strength as possible to clean out the jets, etc. See if this doesn't end the problem. If not, you may need to rebuild the carb --- my guess is that your problems are carb problems.
How many miles do you have on this engine? Is it the stock 350? How many carbs are on the engine --- just one 4-barrel I hope.
Old Dec 30, 2006 | 01:55 PM
  #42
happiedazs's Avatar
happiedazs
Originally Posted by eole
Tthe weather was bad, whole day of rain, so I could do some more testing.
I have turned some screws on the carburator, mxture, idle speed and have some readings.
I have no idea how I can post them here, so I made a site with the explanation.
Could you check my testing and give me some feed back so that I have an idea what to do next. To be sure, I'll recheck all the vacuum hoses.
http://users.skynet.be/fa604708/vacuum-tuning.htm
After looking at these pictures, your vacuum seems low --- what engine is in this car? Is it stock or does it have an aggressive cam? How many miles on the engine? If it's not the carb, then it might be a valve problem. How long have you had this car and how long did it run fine before this problem cropped up?
Old Dec 30, 2006 | 01:57 PM
  #43
Durango_Boy's Avatar
Durango_Boy
I was thinking his vacuum looked low too. I'm pretty sure he has an un-found leak somewhere that may make it hard to diagnose properly.
Old Dec 30, 2006 | 02:10 PM
  #44
David Ey's Avatar
David Ey
Well, I dont know if you still have the problem but if you do I would check, as somebody already said, the vac hose going to the tranny modulator valve may have a hole somewhere. Check modulator hose by plugging where it connects at motor. Or most likely the brake booster. Pull out the big vac hose going to it and plug the hose. Start motor and see if you still have the problem.
Check for leaks at intake by lightly spraying starting fluid around gasket surfaces and carb base while motor is running. If rpm increases you have found a leak. Try tightning the bolts
Old Dec 30, 2006 | 03:07 PM
  #45
Durango_Boy
This is exactly why the C3 vacuum system sucks. There are so many places it spiders around that tracking down a leak is like trying to find a piece of hay in a stack of needles. Ouch.
Old Dec 30, 2006 | 04:03 PM
  #46
eole's Avatar
eole
As it is after 22:00 I cannot start the engine (noise isn' t permitted after 10 o'clock PM)
it is the orginial engine, one Rochester 4MC, next week (next year) i'll try the gumout
Old Dec 30, 2006 | 04:05 PM
  #47
eole's Avatar
eole
stock engine - original , 86.000 miles. I bought the car 1 year ago. It run without any problem for 5 months, it did run fine without any problem.
Old Dec 30, 2006 | 04:06 PM
  #48
Durango_Boy
My Dad's from Germany. Never met his parents from what I understand, but my Grandparents, the ones that adopted him, traveled there a lot. I always wanted to visit Germany, learn German, and drive German sports cars and get a Rot as a pet. Hmm...seeing a pattern?
Old Dec 30, 2006 | 04:08 PM
  #49
eole's Avatar
eole
Can you tell me what the tranny modulator is? The brake booster has been checked, I pulled vacuum at 7,5 psi and stayed, after minutes theirs was a little loss of 10 %. I will pull of all vacuums that aren't needed and restart my testing.
Old Dec 31, 2006 | 09:27 AM
  #50
sly vette's Avatar
sly vette
I agree. But all the vac lines have only one source...the engine. If you eliminate systems at the eng. thru the process of elimination, it becomes quite simple.
Old Dec 31, 2006 | 09:48 AM
  #51
Durango_Boy
I think the big problem is your system vacuum should be in the area of 15. Never lower than 10. That indicates a problem in itself.
Old Jan 3, 2007 | 01:15 PM
  #52
eole's Avatar
eole
Default vacuum confirmed problem
I've done some more testing by reading the threads above.
I think the vacuum problem is the one that's the most important for the moment. As longs as this one isn't solved, looking for other solutions is, in my eyes, a waste of time.
I've described my testing in the url hereunder, and I think I come to the conclusion that the carburator needs to get off, and has to receive a new seal. But before I do this job, which is totaly new for me, I would be shure that this is the thing to do. And if it is difficult, is there a step-by-step explanation how to do it? The only explanation I have is the one in Haynes. IF this is the good one, I'll manage my way throught it.
At the same time I'll change the seals from the valve covers which are pulverised. I think a lot of the seals may be damaged due to the 5 year non activity (the car was in a garage for 5 years without driving it).
http://users.skynet.be/fa604708/vacu...ke-booster.htm
Old Jan 3, 2007 | 07:08 PM
  #53
Durango_Boy
Taking the carb off is very easy, if you go slow and step by step. Take pics of it from all sides before you remove it and document the linkages, washers, pins, and everything else before bagging them. Makes puttin it all back on much faster.
Old Jan 13, 2007 | 04:06 PM
  #54
eole's Avatar
eole
Default a happy man
HI
some feed back
as you know I changed the hoses which were having vacuum problems. I sealed the hoses which I did not need anymore (cannister and lights).
I found a broken valve cover seal, I changed the pcv valve gommet.
I take off the carburator and found a broken seal too.
I rebuild everything, started the engine and drove off for the rest of the afternone.
For your info, I'm building my own small corvette site with the experience of my problems. which can be seen at the above mentionned url
THANKS!! and again thanks to all of you who helped me.
one of these you will find all the pictures of my problems
meanwhile you can see the car after my afternoon drive
http://users.skynet.be/fa604708/corvette/corvette.htm
Old Jan 15, 2007 | 01:28 AM
  #55
happiedazs's Avatar
happiedazs
I'm Glad you're back up and running fine. Now replace those missing Aluminum rocker panel covers ---- andHappy New Year !!!
Old Jan 15, 2007 | 10:36 AM
  #56
Durango_Boy
eole - I used to have a few extra chrome trim rings for the wheels...I can look for them if you need one for that back wheel.
Old Jan 22, 2007 | 04:02 PM
  #57
eole's Avatar
eole
yes I'm interested
if the price is ok
europe and america can built a bridge :-)
I've lost one during a drive.
Old Jan 27, 2007 | 01:56 PM
  #58
Durango_Boy
yes I'm interested
if the price is ok
Yeah, sorry about this, but I checked for those spare rings and they were not in good shape when I found them at the bottom of a spare parts pile. Sorry.
