Help us Maximize our speed!
1. the car is now approved for exceeding 200 mph (passed safety inspection - parachute 2 fire systems etc)
2. Driver licenced to 175 mph
We also became painfully aware of our shortcomings - we knew we didn't really have the HP to make 200 - but we didn't realize our gearing and tire size would be such an issue at that high of speed -
essentially we get to about 165 - 170 - and the wind wrong rear end, and fat tires etc wouldn't let us go any better!
So we need to do several things to get ready for the World Finals next month!
1. we will change out the rear end today - we were running a 2.73 - we will up it to the 3.08. we have a 3.73 available - but the math says - no way -
I tried running the numbers with a 3.33 and that didn't look very promising either!
2. we will be switching out the tire arrangement to tall 28.5 - 29.0 inch diameter much skinnier tire. The problem here becomes finding a rim that will hold a very skinny (4 - 5 inch ) tire with appropriate backspace - and be approved by scta.. I tried running the numbers with a smaller diameter tire - 24.5 - 25 inch - but that doesn't look to promising!
What happened with the 2.73 rear end is that the car could not maintain it's speed in 5th gear - to much wind resistance!
So we are hoping - with the 3.08 - more RPM per speed unit - maybe a better chance of maintaining and even slowly building speed!
What do we run -
ZZ4 with a hotcam
I have the HP and torque curves and numbers - but no scanner available. the engine peaks out at 394 HP at 5750 RPM. Torque maximizes at 417 ft lbs at 3500 RPM.
we do have a custom built carb maximized for the engine and application - think of a Holley 950 - maximized!
We need to figure out the best shift point between 4th gear (1.00 : 1) and 5th (0.68:1).
We also have the added advantage of the bubbled out rear window - that saves us quite a few ponys as compared to the turbulent drag created by the earlier flat window styles!
anyone with any help - physics, application, experience, ideas!
carl "i feel the need for speed" johansson
I have a professionally rebuilt 3:08 available if you need one.
I don't know if the extra bit of torque is going to help with the wind resistance, it sounds like you're going to need more horsepower.
you can "radius" the wheel wells - I'm not sure how to do that - we will be running Moonie wheel covers to smooth the flow!
thanks for the offer of the 3:08 - we fortunately already have a good sound one - we use it for some of the faster Road Racing courses - so it is pretty beefy - at least so far!
Carl Johansson
Regardless - you are right we would need more HP - but right now - there is nothing bolt on about that - we have maxed out the engine and carb we have - to get more HP - entails new motor - or at least all new internals.
So right now wwe are just interested in getting the max speed we can get out of this set-up!
Carl Johansson
The trick of top speed running is to have your gearing and tire diameter put the engine speed right at its power peak as you hit your target speed.
I have a program called Car Test 2000 that can model top speed. If you would like I could run some tests for you.
http://www.cartestsoftware.com/cartest2000/index.html
BigBlockk
Later.....
BigBlockk
Later.....
I think the lowest estimate we got for a C-3 was 500 HP - but that doesn't take into account the bubbled rear window etc.
as for Putting engine speed at Peak power - would that be HP in that case we want 5750 RPM - but if we are looking at Torque - well then you are looking at about 3500 - thats quite a big gap!
One of the problems we are having is the big drop from 4th (1:00 : 1) and 5th (0.68 : 1)
So we are thinking that our focus needs to be on the shift point between 4th and 5th.
I would love to see ya run some simulations - what info do you need?
Carl Johansson
CHeck out the speed analyzer on the Keisler site, lets you fool around with tire size, rear end etc. According to the site my car will go 260MPH @ 6500 RPM
I have doubts too that you can get there with that much hp.
And you certainly wouldn't want to shift into 5th with the current setup. To determine shift points, replot the power curve from your dyno with the x-axis being the car's speed. There'll be a curve for 4th gear and another one for 5th. Shift when the two cross if you can. But in this case, that will probably be beyond your redline.
1) Engine size.
2) Peak horse power and torque if you have them. (I can model something on my dyno if need be).
3) Engine redline.
4) The number of forward transmission gears, their ratios and the rear end ratio.
5) Tire circumference.
6) Coefficient of drag.
7) Frontal area. For a Corvette this is something like 22 Sq/Ft.
8) Overall height.
9) Overall width.
10) Ground clearance.
That should do it.
I decided to go ahead and run some of the numbers you posted. All of these simulations were run with 28.5" tall tires and a coefficient of drag of .40 (this is probably a little better than your car).
The first run is with your 2.73 rear gear using only 4 gears. The simulation came up with 167 MPH at 5300 engine RPM.
The second run is with a 3.08 rear gear using only 4 gears. The numbers were 167 MPH at 5950 engine RPM.
The third run is with a 3.55 rear gear using 5 gears. Your car slowed down to 163 MPH at 4570 engine RPM.
The forth run is with a 3.73 rear gear using 5 gears. It did a little better at 165 MPH at 4850 engine RPM.
The fifth run is with a 4.11 rear gear using 5 gears. You're back to 167 MPH at 5400 engine RPM.
The sixth run is with a 4.30 rear gear using 5 gears. Your car is holding at 167 at 5660 engine RPM.
As you can see from the data the engine RPM at the target speed must be close to the peak horse power. In your cast that would be 5750 RPM. That overdrive transmission is doing you no good. Also 167 maybe 168 is about all you can do with 394 HP.
Just to see what would happen, I built a 565 HP engine on my dyno and ran it in the simulation with no changes except raising the redline to 7500 RPM. The best I could get out of it was 191 MPH at 6800 RPM. Pushing the combination to 650 HP finally got me to 201 MPH.
You have your work cut out for you.
BigBlockk
Later.....
- I assume you are running a Tremec 5 sp with the .68 OD. There is a roadrace version with something on the order of a .83 OD that would reduce your RPM drop going from 4th to 5th. I assume you don't want to do a new tranny right now.
- Normally transmissions are most efficient (less power loss) at a 1:1 ratio. I've always heard that you lose 3-5% in OD versus 1:1. Might want to consider running it in fourth.
- I have no experience running topspeed events, but I would assume that you really want to be at your peak Horsepower RPM at top speed. Horsepower is a measure of work. Theoretically you want max work (engine) to occur at max speed (vehicle) to have your setup optimized.
- I did a quick calculation. With a 27" tall tire running in 4th (1:1) with your 2.73 rear you should be at 169 MPH at your HP peak rpm (5750). A 28" tall tire will give you 175 MPH at the same RPM. So you might want to consider just running your current setup in 4th (with the appropriate tire).
Anyway, hope this helps.
Regards.
Back then I had a stock nose extended chin spoiler 25.4 inch front tires with the 550# one inch shorter springs. My 79 had the nose down to create front rake.
BigBlockk
Later.....
BigBlockk
Later.....
IMO - From my times out for speed week. I'd get the nose on the ground and the rear up. I'd also do some real calculations on rpm VS speed.
That blue "Sundowner" Vette every year was way over 200 mph and they would let 8-10 different people hop in behind the wheel for passes. I think that it went 240 mph or something 15 years ago with a TT motor.
Make a gap filler for the front edge of the T-top so air flows over the top of the car better. You may also want to experiment with blocking off the front grills to see how that helps with front down force, the less air under the car the better.
BigBlockk
Later.....
If you look close on the rear window You can see "AA" So it might have some 700+ ci mountian motor
AA 501 cid and over 8.21 liters and over
A 440 thru 500 7.21 to 8.19
B 373 thru 439 6.11 to 7.19
C 306 thru 372 5.01 to 6.10
D 261 thru 305 4.27 to 5.00
E 184 thru 260 3.01 to 4.26
F 123 thru 183 2.01 to 3.00
G 93 thru 122 1.51 to 2.00
H 62 thru 92 1.01 to 1.50
I 46 thru 61 0.76 to 1.00
J 31 thru 45 0.51 to 0.75
K 30 cid and under
This pink car is a "D" class. So it has to be 305 ci or less and in GT N/A gasoline. It was a 9000 some RPM screamer injected
The top orange car would probably be right on the A 500 ci limit and A/GMS the G stands for Gas M for modified class S is for partialy streamlined
[B]If you look close on the rear window You can see "AA" So it might have some 700+ ci mountian motor
K 30 cid and under
[I]The top orange car would probably be right on the A 500 ci limit and A/GMS the G stands for Gas M for modified class S is for partialy streamlined
Back to Carl's car, it seams to me that his combination is doing all that it can do. My simulation says so and apparently his car does to. With the data that I have so far, his engine is not strong enough to move the car through the air at more than about 168 MPH. His track time mirrors the simulation. The car is having trouble getting past the high 160's, no?
If someone can get more accurate coefficient of drag numbers I would be happy to re do the simulation.
Pushing a stock bodied car over 200 MPH has never been easy and it never will be. There is a reason for that.
BigBlockk
Later.....
