U-Joints
Old Sep 18, 2006 | 07:04 PM
AmpedC3's Avatar
AmpedC3
Default U-Joints +=====+ getting off half shafts
Im trying to get these u-joints off my halfshafts, and they won't budge. The U-joints on my drive shaft popped off with a few wacks of the hammer , but these other guys won't even move? Should I try heating them up, or do I need to get them pressed off? Thanks guys.
Old Sep 18, 2006 | 07:21 PM
shafrs3's Avatar
shafrs3
You can try putting them in a healthy vice and use a socket slightly smaller than the bearing cup to press them. It will help if you clean the crud out from the side your pressing out of to assure a clear path. Obviously you can't get them all the way out this way but will get them started, then you can finish the removal with the .
Old Sep 18, 2006 | 07:26 PM
wombvette's Avatar
wombvette
Read on down to this thread.
http://forums.corvetteforum.com/show...post1556954637
Old Sep 18, 2006 | 07:28 PM
jdmick's Avatar
jdmick
My Minnesota rust welded joints were totally froze in. A little heat from my acetylene torch and cutting out the crosses so you only have to push one cap out at a time took care of things.
Old Sep 18, 2006 | 07:39 PM
norvalwilhelm's Avatar
norvalwilhelm
I am totally against pressing U joints off. If you do you can NOT press off the outer Ujoint with the flange without bolting the flange to a supporting plate. If you do not support it you will bend it.
I cut the X out with a torch and then use an air chissel to walk the hot end caps out.
Like soldering cleanliness is everything for reinstalling.
Again I do not recommend force. Use heat
Old Sep 18, 2006 | 09:01 PM
AmpedC3's Avatar
AmpedC3
I got r dun. I only had to heat one side to get it out, and the others I were able to bang out.
Here comes the paint.
To U-Joints
