Pedal height difference, clutch vs. brake
Old Sep 18, 2006 | 10:35 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Pedal height difference, clutch vs. brake
Can someone tell me how much further the clutch pedal is forward the brake pedal,..from the middle of the pedals. My delta is 1.25",..seems it should be more.
Thanks,
Wes
Old Sep 18, 2006 | 11:29 PM
Z-man's Avatar
Z-man
Mine are at the same level - always have been. However, I have manual brakes.
Old Sep 19, 2006 | 06:18 AM
crazywelder's Avatar
crazywelder
Clutch pedal is slightly higher than the brake pedal. Manual brakes.
Old Sep 19, 2006 | 07:37 AM
...Roger...'s Avatar
...Roger...
Same level from what I've seen.If it is coming up too high its probably the bumper at the top limit brace.The brace itself can bend.If the bumper is gone and your adjusting the proper 1/2 inch freeeplay at the top of pedal you could be over releasing the clutch.Some cars had a quick action position but I think that was C2s.
To Pedal height difference, clutch vs. brake
