Window does not roll down
Old Sep 19, 2006 | 01:56 PM
spille85's Avatar
spille85
Default Window does not roll down
Hey everyone, I am stuck at this moment. My drivers window does not roll down. I hit both switches and only the passengers window went down. I tried the drivers side window, but nothing happens.
I took the plug that normally goes to the drivers switch and place it on the passengers switch...nothing happened, so I took the passenger plug and plugged into the drivers switch and it worked...so the switches are working...what now? Are they are seperate fuses or connections i should look at. Any suggestions. thanks alot marty
Old Sep 19, 2006 | 05:30 PM
GTR1999's Avatar
GTR1999
I don't have a 79 schematic in front of me but it's probably not much different then my 72. I had a problem with intermittent power. Get a meter and trace it from the switch back to source. I had a bad PW realy under the radio left corner. Lectrci Limited makes them now and I swapped it out and solved the problem.
