cabin air flow question
Old Sep 20, 2006 | 11:22 AM
rastadr's Avatar
rastadr
Default cabin air flow question
i see no reason why i would EVER need to mix outside air with my cabin air. to me it just sabotages the temp. with this in mind. how do i keep the outside air doors from opening?
Old Sep 20, 2006 | 11:48 AM
Durango_Boy's Avatar
Durango_Boy
If you never want it open? Disconnect the vacuum line and cap it off. Then fix the door to a closed position however you see fit.
I would avoid permenant closure in case you ever change your mind.
Old Sep 20, 2006 | 12:01 PM
noonie's Avatar
noonie
If you set your a/c to max setting this closes off the outside air and recirculates the cabin air.
Not a well known fact is that when in the max position in a cold cabin it puts higher pressures on the a/c system and compressor especially, thus a shorter lifespan.
Realizing this, auto manufacturers, sick of high waranty claims, and now with electronic controls for a/c, have made the system default to fresh air for a/c whenever the vehicle is restarted.
The recommended usage is to use max a/c to quickly get the cabin to a comfortable temp and from that, then the regular setting (a/c with fresh air) should be used.
Old Sep 20, 2006 | 01:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are plenty of reasons to mix in some fresh air...the biggest one I can think of is to simply keep the air in the cabin fresh.
Old Sep 21, 2006 | 11:32 AM
Durango_Boy
If I want fresh air I take the tops off and kick out the back window. I've noticed I have to drive in the winter with the windows cracked anyway since the defrost does such a crappy job. I breath hot and heavy and my window gets fogged fast...
Old Sep 21, 2006 | 01:23 PM
ESU's Avatar
ESU
The defroster needs outside air to help clear the windows. If you've sealed up or otherwise negated the ability of the system to induct outside air you will experience fogged windows. And it wont be from staring at your old avatar! I sealed the flapper door inside the pass side fender well behind the screen with good old american duct tape. Took 10 minutes to do and will take 10 mins to undo if I so desire. I wanted the best possible cooling for the summer, not so worried about winter.
ESU
Old Sep 21, 2006 | 01:26 PM
Durango_Boy
ESU
Heh, good call about the avatar. But the fogging happened with the door working properly, so outside air was allowed into the system. Maybe my vents suck...or blow, or whatever they do.
Old Sep 21, 2006 | 01:50 PM
SIXFOOTER's Avatar
SIXFOOTER
It also helps keep the mold out of the ductwork
Old Sep 21, 2006 | 03:09 PM
ESU's Avatar
ESU
Does your a/c work? Need working a/c also to properly clear the windows.
ESU
Old Sep 21, 2006 | 03:16 PM
Durango_Boy
ESU
Nope...I removed the compressor, but kept the HVAC controls.
Old Sep 21, 2006 | 05:37 PM
ESU's Avatar
ESU
That explains the fogging.
Old Sep 21, 2006 | 05:39 PM
Durango_Boy
So how did non-A/C cars battle the fog? I'd like to get the problem solved before my next winter of driving, which could be in a few weeks...
Old Sep 21, 2006 | 10:38 PM
vett79's Avatar
vett79
Along these same thoughts...........I disconnect my heater hoses in the summer to help the AC. My Sanden conversion is almost too cold sometimes but the temperature control lever semmes to make no diffrence. Does the heater have too be working and the vacuum water valve working to adjust the temp??
Old Sep 21, 2006 | 10:43 PM
doug_dayson's Avatar
doug_dayson
Yes, and the Blend Door Cable needs to be adjusted correctly...
Doug
Old Sep 22, 2006 | 03:14 PM
ESU's Avatar
ESU
It was a losing battle, you got cars with two little batmobile like clear spots and that was it. How many foreign cars have you seen go by in the winter with all fogged windows. In American cars when you turn on the defroster the a/c also comes on, in foreign cars most of the have a seperate switch to turn on the a/c compressor which they never do in the winter hence the fogged windows.
ESU
Old Sep 22, 2006 | 03:53 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
For fogged windows get Rain X FOG and put it on the inside of the windows works well. Not to mention Rain X on the windsheild for rain and they also now have window washer fluid with Rain X in it. Does a great job.
Old Sep 22, 2006 | 03:58 PM
noonie's Avatar
noonie
If you have the a/c disconnected, then you must do what non a/c cars do, and that is use the heater for the defrost and defog. It works very well, but depending on the ambient temp it may get a little toasty inside. You may not have to run it very long or adjust the temp lever to mix heated air with outside air to get warm instead of hot.
As mentioned prior by ESU and doug_dayson, the blend door adjusts the temperature inside the cabin with both the a/c and heater working.
For winter driving, you can put a switch to manually turn off the a/c compressor for gas mileage, so it does not run in the cold weather. It is adviseable to run the a/c once in a while all year long to keep the compressor shaft seals in better shape.
Old Sep 22, 2006 | 04:05 PM
Durango_Boy
Well...I took my AC out. Probably won't bother hooking it back up unless I do it with the new motor's serp system. I'll have to re-install a few parts. I don't think I will ever put it back in. I liek the tops off and windows down approach to summer driving. If I want AC I'll drive my Durango.
Now, as far as the heater, I plan on using that and a combo of a cracked window to regulate the air temp in the cabin. Would have worked well last few winters but the blower motor and duct system sucked.
To cabin air flow question
