Fuel Sender Unit
Old Sep 20, 2006 | 04:50 PM
UK Jerry's Avatar
UK Jerry
Default Fuel Sender Unit
Hi.
I was wondering if anybody can help me.
I have just taken my fuel tank out and I would like to test the fuel sender unit does anybody know how to do this?
I tried to connect it back onto the car but the fuel gauge now seems to read full and won't budge, this would be great, as it would mean I would never have to fill the tank up again
But unfortunatly it is not in the tank.
Old Sep 20, 2006 | 05:09 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, take out the sending unit, hook up the connector and move the float arm through it's entire range of movement.
Old Sep 20, 2006 | 09:07 PM
...Roger...'s Avatar
...Roger...
And ground it
Old Sep 20, 2006 | 10:22 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The fuel sender is a simple unit that is basically called a POT or a variable potentiometer. A potentiometer is a resistor that will change the resistance on a wire when moved up or down a wrapped resistance wire. The sending unit is easy to check too! The Ohms resistance should read 0 for empty and 90 for full for all C2 and c-3 cars. C-1 cars had a different resistance of ohms for full (32 Ohms is full).
If you are having problems with your sending unit or dash unit, it’s a simple test to see which is bad. Ground out the Ohms wire (tan) that fees a resistance reading to the gauge in the dash! Do this at the sending unit and the dash gauge should go to a “buried” full reading. If you do this at the back of the tank and the gauge pegs full, then you know you have a problem with the sender. If the gauge won’t peg, then you either have a problem with the dash gauge or you have a problem with the wires that feed the ohms reading to the gauge.
More times than not, a dash gauge that is stuck on a pegged full reading has a shorted wire!
Willcox
Old Sep 21, 2006 | 03:51 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by UK Jerry
Hi.
And there was an article in the October edition of Corvette Enthusiast on fuel sending units that speaks to the topic.
Old Sep 27, 2006 | 04:56 AM
UK Jerry's Avatar
UK Jerry
Thank you for all your help,tested the sender unit and found a bad conection, took it apart and hey presto it now all works , so once again many thanks . 1 less thing to fix on my ever ending list.
To Fuel Sender Unit
