Need help with my 74 CLOCK....
Old Sep 13, 2001 | 03:03 PM
Alwyn678's Avatar
Alwyn678
Default Need help with my 74 CLOCK....
Anyone know if there is a **** on the clock(in the dash) to adjust it?? I just have a piece of metal sticking out that is slippery!! :crazy:
Old Sep 13, 2001 | 03:06 PM
Pedro'74's Avatar
Pedro'74
Default Re: Need help with my 74 CLOCK.... (Alwyn678)
Yup, there's a small chrome ****. I believe most of the catalogs sell them.
-Pedro
Old Sep 13, 2001 | 03:07 PM
Lohkay's Avatar
Lohkay
Lol...well mine had a **** on one of the low end corner of the clock so I guess that piece of metal is where the **** WAS. And I think you had to pull it to turn it....its been a while I ajusted it cause it doesn't keep time and gave up on it a while ago.
Old Sep 13, 2001 | 03:10 PM
Alwyn678's Avatar
Alwyn678
Default Re: Need help with my 74 CLOCK.... (Pedro'74)
Ahhhhhhhhhhhh I see does it screw on or something??
Old Sep 13, 2001 | 03:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. Your slippery piece of metal ought to have a small chrome **** on the end of it. Mine was literally broken off with only two or three threads remaining. I ordered a replacement shaft and made the swap myself. The shaft and replacement ***** are available from the aftermarket providers. There are two different *****, depending upon model year, and they have a small lock nut to hold them in place. The lock nut comes with the replacement **** kit. FWIW, you should also have a small piece of black tubing over the shaft inside the gauge cluster.
Old Sep 13, 2001 | 05:34 PM
76Stinger's Avatar
76Stinger
Default Re: Need help with my 74 CLOCK.... (Easy Mike)
I'm thinking there is a very small set screw in the end of the shaft that holds the **** on. Could be wrong.
STW
Robert
76Stinger
To Need help with my 74 CLOCK....
