dual fan question
Old Sep 21, 2006 | 10:23 PM
Dukes79's Avatar
Dukes79
Default dual fan question
Anyone running a dual electric fan set up, do you have both fans kick on at the same time with the electric thermo switch or do you have one running all the time and the other kick on with the thermo switch? Thanks for any help!
Old Sep 21, 2006 | 10:59 PM
SIXFOOTER's Avatar
SIXFOOTER
Many ways to do it. Theres the PWM controllers, seperate thermal controls, relays off your existing temp sensors, multispeed...
Old Sep 22, 2006 | 03:35 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Mine are both controlled by the same temp switch, using relays for each fan. They come on and off together. Be sure to have your alternator beefed up too at the same time.
Old Sep 22, 2006 | 12:51 PM
72LS1Vette's Avatar
72LS1Vette
The SPAL controller turns on one fan at low speed at the low temp threshold and has a wire to activate a second fan at the high temp threshold. The first fan would also go to high speed at the same time.
Rick B.
To dual fan question
