Is This Normal
Old Sep 21, 2006 | 10:48 PM
Tim81's Avatar
Tim81
Default Is This Normal
I recently purchased my first Corvette. It's a 81 and my question is, when I shift it into drive I can feel the rear end sink down about an inch or two. When I shift back to park or neutral the rear end comes back up. Is this normal or is something wrong? The car seems to handle fine. Thanks for any info in advance. I hope that I haven't been asking to many questions.
Tim
Old Sep 21, 2006 | 10:55 PM
SIXFOOTER's Avatar
SIXFOOTER
Don't ya just luv it? Thats normal
Old Sep 21, 2006 | 10:57 PM
surfshark's Avatar
surfshark
Yep, it's normal. If it clunks though, that's when you have to check it out.
Old Sep 21, 2006 | 11:02 PM
...Roger...'s Avatar
...Roger...
Normal but make sure your idle is not too high-idle too high makes that dip worse.
Old Sep 22, 2006 | 07:50 AM
Tim81's Avatar
Tim81
Thanks for the info. I does feel cool.
Old Sep 22, 2006 | 09:23 AM
bickel's Avatar
bickel
gotta love the dip reminds me of a summo wrestler getting ready to charge!!HUUHT 81 owner here to!!
Old Sep 22, 2006 | 04:16 PM
kdf1986's Avatar
kdf1986
Corvette Squat!!!!
kdf
Old Sep 22, 2006 | 09:07 PM
toddrob's Avatar
toddrob
What would a clunk indicate?
Old Sep 22, 2006 | 09:30 PM
corvette4life's Avatar
corvette4life
This is typical with the original fiberglass rear spring and a car of this age. The fiberglass springs don't sag with age like the metal springs but they do get softer. Even more noticeable with old shocks. If the rear feels "floaty" over bumps in the rear I would consider replacing the spring.
It won't hurt anything but it will feel soft in the rear.
Old Sep 22, 2006 | 09:46 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Typically "clunk" means check your U joints.
Old Sep 22, 2006 | 09:49 PM
toddrob's Avatar
toddrob
What is the procedure for checking the U-joints?
Old Sep 22, 2006 | 10:01 PM
73-84 IMSA Widebody
They begin to "clunk" from wear, they become loose or sloppy allowing excessive play, if you here them clunk you can usually move them by hand, or get under the car and have someone put into drive-neutral-drive etc. (carefully, try not to get run over)until you can determine which joints are worn. It can be drive shaft or rear end half shaft joints. If they are worn I would usually replace all, at least all drive shaft or all rear end joints unless they are relatively new and there is a reason one has worn excessivly. It's also possble to get the "clunk" in your transmission, but that is a far bigger problem.
Speaking of problems, is THIS normal>>:<<Click for larger view
Old Sep 22, 2006 | 10:21 PM
vettecrazy88's Avatar
vettecrazy88
Yep normal. Gettin ready to jump!
Old Sep 22, 2006 | 10:41 PM
3rd_Vette's Avatar
3rd_Vette
Perfectly normal.. the next thing you will notice is when you get on the highway, other Vette owners will wave to you!
Old Sep 22, 2006 | 10:47 PM
eileenthevette's Avatar
eileenthevette
THAT is nowhere NEAR normal.
To Is This Normal
