Water Pump Recommendation
TJ
TJ
TJ
TJ
Brett
As been mentioned already many times a higher flow pump will move too much coolant too quickly not allowing time for the coolant to pull the hear out of the motor and not allowing the radiator to cool the coolant down enough. The "higher performance" part now defeats the entire purpose of it's use.
This is one of the reasons that in a LOT of cases it's just better to stick with a stock part rather than a catalog "hot rod" or "racing" part.
Race car parts belong on race cars, not on street cars.
If you call up a place like JEGS or Summit though they won't tell you that because they are in the business to sell parts. They will just accept your order and take your money and than after you install this "higher performance" part on your car and wonder why things aren't working right they will just shrug and say "I don't know".
They is a VERY, VERY wise man over on the C1/C2 section who also use to be an engineer for GM in the corvette division under Zora.
He has said something many times that I've seen backed up by other experiences on the forum countless times already.
what he says is: "when you don't need to, don't reengineer what you don't have to". Actually that paraphasing it because he has said the same thing in a few different ways many times.
GM spent a LOT of time and money engineering every system on the car to work properly together. For example, on the the cooling system, they didn't just choose a particular style and volume water pump simply because they were offered a good deal on it from a vendore. It's designed to flow the correct amount of coolant that's needed for proper cooling - not more than it needs because that has it's own drawbacks, and certainly not less than it needs because they are in the business of selling cars and do NOT want cars coming back for warranty service because of cooling problems - that reduces profits.
Unless you have a VERY highly modified motor that you are using I'd say mostly for racing usage and very little street use the stock water pump is an excellent unit, very dependable with very low failure rates, and is not very expensive at all so why spend more money on an aftermarket unit that will typically cost more and not work any better and may even not work as well?
TJ
It's like this, if I bought all new GM compnents and totally rebuilt the whole entire car, everything will still start to fall apart after only a few years. Face it, that's the way cars were made back then. The C5ers might tell you they still are...
Anything I can do to improve reliability, performance, and longevity, without ruining the original character of the car, I do.
