Which Shocks
Old Sep 23, 2006 | 10:43 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Which Shocks
Greetings,
I'm getting ready to endeavor into a suspension project...lowering the front (cutting one coil off stock springs). I'm going to change the shocks, and install a VB&P suspension kit. I'm looking for a firm but not hard ride. I was planning to go with Bilstein HD's over the sports, but was also considering a maybe a KYB adjustable.
Any opinions on which is the better shock for a firm but comfortable street app?
thanks in advance.
Old Sep 23, 2006 | 10:55 AM
rihwoods's Avatar
rihwoods
From what I've read here,KYB's seem to be the choice with composite rear springs...I'm running Bilstein Sports with a new Guldstrand steel seven leaf...stiff..but I prefer the firmer ride...
I used to run a TRW/KYB's but spring was #330 and not stiff enough for the 69 502..
Rich
Old Sep 23, 2006 | 02:02 PM
doug_dayson's Avatar
doug_dayson
I'm running Bilstein Sports with a custom VB&P 345lb composite rear, and 500lb fronts (cut VB&P 460's in a 406ci SB 71 Coupe). They work great (no bouncing problem in the rear etc)...
Doug
Rich
To Which Shocks
