broken ram bracket
Old Sep 23, 2006 | 12:27 PM
GTR1999's Avatar
GTR1999
Default broken ram bracket
Has anyone ever broken a PS Ram bracket? The kids 75 broke and I have never had this part break before on any of my vettes?
Old Sep 23, 2006 | 12:40 PM
rihwoods's Avatar
rihwoods
Maybe it was out of alignment....when I replaced seals in my 78 ram,the shaft looked very slightly tweaked...not enough to bother with in my case...
Rich
Old Sep 23, 2006 | 01:06 PM
Bob Onit's Avatar
Bob Onit
Theres a guy in Killingworth, Exit 60 something (near guilford) of I-95 parting out a 73 small block if this will help
Old Sep 23, 2006 | 01:23 PM
GTR1999's Avatar
GTR1999
Alignement was ok, I just rebuilt the system about 2k miles ago.
Bob, you have the number of this guy? Bargin News?
I have to look in my parts collection, I may have one here. I just had this part fail before?
Old Sep 23, 2006 | 01:39 PM
Bob Onit's Avatar
Bob Onit
He doesnt list it every week but I have the guys number
Ill PM you the number.
Old Sep 23, 2006 | 02:34 PM
...Roger...'s Avatar
...Roger...
I had one break 2 ears off the base but I think it must have been left loose in its past.
Old Sep 23, 2006 | 05:20 PM
jwp75v's Avatar
jwp75v
Just had to replace mine 75 with 30k miles two ears broke.
Old Sep 24, 2006 | 10:15 AM
GTR1999's Avatar
GTR1999
yes the 2 inner ears broke on this one too. It was the original one judging from the condition I bought the car in 4 years ago. I had one on the shelf in the garage so the car is back on the road.
Thanks Bob for the help.
Gary
Old Sep 24, 2006 | 11:01 AM
...Roger...
This happens often if these bolts are left loose.Its a good practice to always check those bolts when relpacing the ram.Sounds like a valuable lesson was learned that all can benifit from.
Old Sep 25, 2006 | 07:35 AM
...Roger...
Gary did you check the frame under the bracket? I have seen the frame crack from the constant bending back and forth under the 2 remaining tight bolts.The frame is overlapped and usually unwelded in that spot hence the step in the bracket.
Old Sep 25, 2006 | 08:11 AM
GTR1999's Avatar
GTR1999
I did check it and it is not ripped or cracked. Yoy're right that is an area of frame failure. Good point for others to check.
Gary
To broken ram bracket
