I am in the process of replacing the plugs and wires on my 76. I started on the passenger side and was wondering if anyone out there has any advice on how to replace the wires for the front 2 plugs. They run through a shield behind the starter and then through the motor mount.
I haven't looked at the drivers side from under the car yet but it looks a little easier. Are there going to be any suprises on that side?
Use some WD-40 and take the boots off and attach to old plug wires and pull slowly and push the new ones-if the new ones slide against a sharp edge it will slice them.EDIT-push more than you pull.
Or you can do it the hard way like I did, loosened the motor mounts and jacked up the front of the engine.
Luckily I was able to change plugs and wires in my '78 while the motor was out so it was easy, but I just had to change ignition wires on my '65 with the motor in and the easiest way is to remove the plug boots, tape them to the the end of the cooresponding wire it is replacing and carefully feed the new wire thru as you are pulling the old wire out. As mentioned, WD40 will help it slide thru easier. Do each wire this way. After the first wire you will get the hang of it and in the end you will find it actually ends up going quicker than you imagine it was going to take you.
Also as mentioned, those shields have sharp edges so just be careful as the new wires can get sliced easily if you aren't paying attention.
i sure remember my first time doing it with the motor still in and all the accessories installed. if you have never done it before, looking at the job it can be a bit intimidating, especially when you realize those front 2 cylinder wires on each side go thru the motor mounts.
Once you do it you realize it's not that bad, but for a first timer I can certainly understand asking the question as he did.
Even after having done it I still never look forward to future times of having to do it again.
just put front end on jack stands,and remove the wheels. alot more room that way. also run the second plug wire from the front first,as the first one will need to be under that wire. good luck
I was thinking of replacing and bringing the new ones down off the valve covers and in to the plugs between the header tubes....I think I've seen a pic of it before and it looked pretty nice the way the guy did it....any thoughts on that?
You will find lots of bubba'd Vettes with plug wires looking more like spaghetti all over the top of the engine, and of course, most if not all ignition shielding removed, all as a result of the frustration and cuts obtained in just trying to do a quick plug wire replacement. Big blocks are definitely easier. There are also some very nice aftermarket plug wire looms for putting the wires up top, if you are not concerned with originality but want to keep the engine compartment neat.
You are experiencing the reason so many people end up routing the wires over the top of their valve covers. I personally think they look better routed in the factory manner and have never had a plug wire burned or fail as a result of doing it this way.
I like to get the universal sets from GM that come without the distributor ends installed. This makes routing them through the looms and shielding that much easier. If you have factory style with the ends already installed, you can sometimes remove them, by spraying them liberally inside with silicone and gently slipping them off. I also remove the V-shields on the side of the block while installing the wires which makes routing the front wires behind the motor mount a lot easier. I do the wires one-at-a-time and put a small piece of masking tape on each wire with it's number before routing just in case I lose track of which one it is. Reinstalling the distributor end boots is pretty easy by using silicone and being gentle.
Good luck... it's a tedious job, but the results are worth it.
I just wish mine would have had the shields on it when I bought it
The wires are over the valve covers and yes I think a stock routing looks better, especially if you have the stock exhaust manifolds. Oh well, another project at a later time.
