Help - my C3 has a Japanese engine in it !!!
Old 09-27-2006, 04:13 PM
  #41
Kalway
Kalway's Avatar
There ya go, BMW switched to GM autos for a good reason.
Old 09-27-2006, 06:58 PM
  #42
Wrencher
Wrencher's Avatar
Originally Posted by hensen1954
Mid 80's BMW
Those were a bad copy of the early Borg-Warner that Rambler/AMC used, among others. Figures they'd copy that one. I laugh every time a customer brings that junk to me with no forward gears, because all you have to do to waste the forward clutch is rev it in neutral/park for about 30 seconds to a minute. Their design does not provide lube to that clutch unless it's in gear! Total junk, plus they were able to pawn it off on Volvo and Peugoet as well.
Hans
Old 09-28-2006, 01:55 AM
  #43
Twin_Turbo
Twin_Turbo's Avatar
I've seen L81 w/ forged but it must have been because the shelf for the 4 valve relief ones was empty, however ALL L83s do have forged pistons, they use the L82 piston, TRW # 464664
Old 09-28-2006, 02:18 AM
  #44
hensen1954
hensen1954's Avatar
Hans
You are talking about the earlier one which did give trouble in my 635csi - the next "switchable" box, did not have this problem, but that does not change my question - what are the losses...........
Old 09-28-2006, 11:43 AM
  #45
copter
copter's Avatar
And why can't we say ***?Why to much pc going on around here.We need to lighten up a bit Gezz
Old 09-28-2006, 01:14 PM
  #46
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
You're one to talk, Mr. Hater.
Old 09-29-2006, 01:35 AM
  #47
Procrastination Racing
Procrastination Racing's Avatar
I use forged pistons exclusively. It's probably overkill, but my engines take a beating and I've never had a piston failure in 34 years of engine assembly. A few connecting rods , but not pistons. Venolia or Jahns are my favorites.
Hans
I've had a forged piston fail once. I dropped an exhaust valve head on top of it at about 7500 rpm, apparently on end from the marks, tried to force the piston out the side of the cylinder from the crack and bent metal in the wall, and then must have shot the valve head back up through the exhaust port and out the headers.
Darn piston failed. It had a hole in the top of it.
Think TRW will give me my money back?
Old 10-02-2006, 10:34 AM
  #48
UKPaul
UKPaul's Avatar
General wisdom on this forum used to put losses at somewhere around 25-30% from the crank to the wheels when pushed through an auto.
Old 10-02-2006, 04:33 PM
  #49
ruby76
ruby76's Avatar
Location: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
I can't believe I read this whole post and haven't seen the picture yet
Quick Reply: Help - my C3 has a Japanese engine in it !!!
