68 wiper mtr. need help
Thanks.
There is a blue wire going directly to the motor housing, the other two wires are red and tan, and go to the mechanism above the motor. Now look at the connector in the harness, there should be a larger red wire, two black wires joined into one contact beside it, and a green or gray wire(can't tell exactly) with the connector slot running perpendicular to the other two. The blue wire(coming from the round motor housing) goes to the two black wires, the red wire goes to the larger red wire, and the tan to the green(or gray) wire.
With your rebuilt unit, the wires as you stated are not correctly color coded, but the one from the motor housing should be easy to spot. Not sure of the other two.
Also be sure the housing has a ground wire going to it.
Hope I've helped rather than make things more confusing
If the motor was missing, hopefully there are not other pieces to the system missing as well.
You're right, the wiper system IS over-enginnered
Emial me at willcox@willcoxcorvette.com if you don't figure it out. I can send you a copy.
-P
