1980 L82
Brian
L48 is a two bolt main while the L82 is a 4 bolt main
L82 has the aluminum intake and free-er flower exhaust (I believe)
L82 had the optional electric cooling fan while the L48 did not
4 speed manual was only available in 80 with the L48 (which drove my decision)
I believe the L82 was listed with 230 hp while the L48 was listed with 196hp (I think)... driven primarily by compression ratio and better intake/exhaust flow.
We built our L48 up extensively and it now dyno's at 406hp at the rear wheels with 486 ft/lb troq. Very solid engine and we are very pleased.
I'll post the source and additional info if I can find it.
Ed
Some other calibration changes too but those parts differences are the highlights.
-Mark.
A couple of the things that I've noticed are:
1. Along with the electrical auxiliary cooling fan. It also has only five blades on the belt driven fan.
2. Along with the L82 badges on the fenders, the tach also says "L82" and has a 6000 RPM redline.
3. The L82 was 230 HP, the L48 was 190. According to the service manual the compression is higher, 9.0 vs. 8.5. The cam has higher lift. The Black Book says the Quadrajet is a different part number. It probably has different metering rods and/or hanger? The distributor is a different part number too. Maybe different counterweight springs?
I found a Car and Driver article online which blasts the new 1980 Corvette. They tested an L48 four speed. The top speeds per gear surprised me
Final-drive ratio 3.07:1
Gear Ratio Mph/1000 rpm Max. test speed
I 2.88 8.5 44 mph (5200 rpm)
II 1.91 12.9 67 mph (5200 rpm)
III 1.33 18.5 92 mph (5000 rpm)
IV 1.00 24.6 123 mph (5000 rpm)
123 mph for the L48??? I wonder what the L82 is capable of?
