Timing tape
Old Sep 26, 2006 | 07:54 PM
mr303's Avatar
mr303
Default Timing tape
Does anybody have a digital copy of a timing tape for use on a standard L48 balancer (.tiff, .eps file or similar) I think the balancer size is 7 1/4 inch.
Old Sep 26, 2006 | 07:59 PM
BarryK's Avatar
BarryK
you canaccomplish the same thing with a piece of masking tape. Measure the circumference of the balancer and divide by 10; this will give you the length of a 36° segment.
Cut a piece of masking tape exactly that length, and subdivide and mark it into smaller divisions (center is 18°, center of each resulting half is 9°, center of each of those segments is 4.5°, etc.).
Then mark the piece of tape with 0° at the left end, 18° in the center, 9° between 0° and 18°, 36° at the right end and 27° between 18° and 36°, and apply it to the balancer with the 0° end aligned exactly on the balancer’s timing index line and the 36° end down, clockwise on the balancer as viewed from the front.
You now have calibrated markings on the balancer from 0° advance to 36° when aligned with the “0” on the timing tab. Or, you can buy a
“timing tape” for your particular diameter balancer from any speed shop and apply it permanently for future “quick checks”.
Old Sep 26, 2006 | 08:04 PM
vettfixr's Avatar
vettfixr
I'll tell you, one of the best things I got for my car is the proform balancer cover. It bolts to the balancer so even if the balancer moves your timing marks are still accurate. It looks good too and its only $29.88. You will also need an adjustable pointer which is also pretty cheap. here's a link.
http://store.summitracing.com/egnsea...s=false&N=+115
Old Sep 26, 2006 | 08:12 PM
mr303's Avatar
mr303
Thanks guys! Masking tape sounds good, I have no problems with buying the correct gear but by the time I convert our dollar and add postage from the US everything gets expensive in New Zealand.
To Timing tape
