Adjusting Modulator
Old Sep 27, 2006 | 11:05 AM
EVIL_GRIM's Avatar
EVIL_GRIM
Default Adjusting Modulator
i work at napa and bought one of the adjustable red striped modulators for the th-350 on my 79 vette. does anyone know which way i turn it to bring my shift points down int he rpm range? or can someone explain to me the details of how it works? i just bought it so i could adjust it so im not 100% sure how to work it.
thanks in advance!
Old Sep 27, 2006 | 11:44 AM
BKbroiler's Avatar
BKbroiler
I had my TH350 trans redone and it has a red striped modulator on it. I lowered my shift point about 300 rpm by turning the small screw inside 1/4 turn clockwise. Hope that helps.
Old Sep 27, 2006 | 09:52 PM
jayr's Avatar
jayr
I used to rebuilt automatics in the 70's & early 80's and I would turn the
screw in or clockwise for higher shift points and out for lower shift points. Lower vacume rises the rpm shift and higher vacume lowers the
rpm shift. The mod. works in operation for the upshifts along with
the governor. But the governor works the downshifts by over riding the
mod pressures.
Old Sep 28, 2006 | 01:55 PM
EVIL_GRIM's Avatar
EVIL_GRIM
dont you have to have like a Valve Core Extractor to turn the tiny thing inside the Modulator?
Old Sep 28, 2006 | 03:33 PM
jayr's Avatar
jayr
Not sure what the napa one that you have got. but the ones I used
to have you used a very small straight blade screwdriver, like the little
ones snap-on used as there promotions years ago. Thats been some
years back. It should not have a valve core as the vac. as to change
in order to change to pressures in the trans.
Old Sep 28, 2006 | 05:09 PM
BKbroiler's Avatar
BKbroiler
I used a very small flat blade screwdriver on mine.
Old Sep 29, 2006 | 01:31 PM
EVIL_GRIM's Avatar
EVIL_GRIM
i was just using that as an example, sorry...it looks like it has 2 small slots inside of it where a small flat head would fit i could only think of a Valve core tool at the time lol
To Adjusting Modulator
