Starting problems
Old Sep 27, 2006 | 01:27 PM
Ratsirt's Avatar
Ratsirt
Default Starting problems
Hi there,
I have a supercharged 350 small block in my 71 which is a recent install. I am now having starting problems after the engine is warm. If I shut it down it needs to be left to cool down for a long time before it will start again. When it is cold it starts fine. The starter has been replaced and also the battery. Setup is equipped with an electric cooling system and MSD ignition. When you try to start after the engine is warm it is as though the battery is low and the starter just drags.
Thanks in advance for any replies
Old Sep 27, 2006 | 01:35 PM
Gordonm's Avatar
Gordonm
Starter heat soak. Very common problem. Get yourself a mini starter and be done with it.
Old Sep 27, 2006 | 01:54 PM
Ratsirt's Avatar
Ratsirt
Thanks,
that is what I had been thinking. The only thing though is it did not do it with the old engine and I had the headers on it.
Old Sep 27, 2006 | 02:41 PM
justanotherdoe's Avatar
justanotherdoe
Is the problem that it doesn't crank, or that it cranks but doesn't catch fire?
Old Sep 27, 2006 | 04:00 PM
Z-man's Avatar
Z-man
My MSD has a cranking spark retard. Is that the way your's is? This reduces stress on the flywheel and starter during cranking for higher performance engines...
Otherwise, you might be able to insulate the starter from your headers like the others have indicated.
Old Sep 27, 2006 | 04:37 PM
Ratsirt's Avatar
Ratsirt
Justanotherdow: It does not crank, it is as though battery is dead.
Z-man: no my MSD does not have a spark retard.
Old Sep 28, 2006 | 09:19 AM
Boofers's Avatar
Boofers
Check that your starter solenoid is getting 12volts when you turn the key. If not then your problem could be the keyswitch, clutch/neutral switch or associated wiring to the solenoid. You may just need to open up your solenoid and clean the contacts.
To Starting problems
