Why is it doing this
Old Sep 27, 2006 | 04:39 PM
Ibuyvettes's Avatar
Ibuyvettes
Default Why is it doing this
On a 79 Corvette when you floor it you can hear that 4 barrel sound but it's quiet, and for about 2-3 seconds the car feels like it's not running at all just coasting, then it finally takes off. Just had a major tune up (timing, plugs, wires, cap, rotor). Car had been sitting awhile but now has fresh gas.
Old Sep 27, 2006 | 05:11 PM
noonie's Avatar
noonie
Sounds like you are getting a mini bog.
You may just be able to loosen the spring pressure of the secondary top plate on the qjet a little so it responds a little faster.
Old Sep 27, 2006 | 07:35 PM
frty9r's Avatar
frty9r
Is your carburetor a Rochester Q-jet. It's called the Quahhhhhrejet lag
Old Sep 27, 2006 | 08:46 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Most likely the secondary spring is not tight enough causing the secondaries to come in too quick. On the seconday air valve shaft (passenger side) there is a allen wrench set screw, coming up from the bottom. Loosen the set screw and adjust the air valve till it just bearly closes then turn the wind up spring 3/4 to 7/8 turn and lock the set screw. DO NOT turn more than one turn it will distort the spring. Ron B.
Old Sep 28, 2006 | 07:33 AM
BKbroiler's Avatar
BKbroiler
A properly set up Qjet will have no "lag" at all.
Old Sep 28, 2006 | 07:56 AM
...Roger...'s Avatar
...Roger...
I would add-when you loosen the set screw the other screw will all of a sudden spring and you will loose the original setting-find a picture-in the end of carb is a straight blade screw-hold it while loosening set screw-then tighten it 1/4 turn then tighten set screw and go roadtest-adjust again as nec.
Old Sep 28, 2006 | 08:27 AM
sperkins's Avatar
sperkins
Old Sep 28, 2006 | 08:37 AM
marshrat99's Avatar
marshrat99
This first thing I'd check is the accellerator pump. With the engine off, remove the breather, make sure the choke is open, then manually operate the throttle linkage and look to see that you're getting a good squirt of gas. If not, then bingo.
Old Sep 28, 2006 | 11:31 AM
tracdogg2's Avatar
tracdogg2
Check the choke pull-off. It controls the opening rate of the air valve. Also you have two fuel pick-up tubes insde the carb and two booster tubes for inital secondary operation. It is very common for 1 or more of these tubes to fall out of top plate and into the float bowl. Since the car finally does start to pull there's a good chance you dropped a booster tube.
Mike
Old Sep 28, 2006 | 12:26 PM
Ibuyvettes's Avatar
Ibuyvettes
I don't know where all these parts are, I need layman descriptions.
Paul L's Avatar
Paul L
I would vote for the accelerator pump. Test as noted above. Adjustment is by bending the rod. Rather crude but it works.
Old Sep 30, 2006 | 09:47 AM
RUSS OBLENES's Avatar
RUSS OBLENES
Thats why the stock Q-Jets are called Quadrabogs.
Russ
Old Sep 30, 2006 | 10:07 AM
SIXFOOTER's Avatar
SIXFOOTER
You need Doug Rowe's book on Quadrajets
Old Sep 30, 2006 | 10:08 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
3rd vote here for the accellerator pump. I agree that there should be no lag on a properly set up Quadrajet.
Old Sep 30, 2006 | 11:06 AM
...Roger...
Ibuy is that flooring it from a standing start or flooring it while cruising?One is a primary problem and one is a secondary problem.
Old Sep 30, 2006 | 11:10 AM
rcastor426's Avatar
rcastor426
if you do not know where these parts are you need to stop... not touch anything and go buy a book. most of these parts we speak of are common on all carbs.... yes they are in different places but if you know anything about a carb you can look at one from the other and know exactly what they are. i am not trying to come of rude but if you start tinkering without a book you could really make it worse.
Old Sep 30, 2006 | 11:51 AM
rihwoods's Avatar
rihwoods
http://www.hardskull.com/qjet/
Old Sep 30, 2006 | 02:34 PM
tracdogg2's Avatar
tracdogg2
If the problem only shows up stepping into the secondaries it can't be the accel pump. The pump stroke is used up. Even if the pump is dead it would't have any effect on the secondaries since they have their own booster circuit.
Mike
Old Oct 1, 2006 | 08:47 AM
GM73VETTE's Avatar
GM73VETTE
Default Bogg
I Am With Mike, The Acc Pump Is Only Used On The First Stroke Of Accellator Peddle Movement.
Gm
To Why is it doing this
