Double hump 461/462 heads
Old Sep 14, 2001 | 02:25 PM
adam's Avatar
adam
Default Double hump 461/462 heads
These heads are the old heads that are supposedly good heads, but they have no accessory holes.
Do you then have to drill and tap the heads for the necessary holes, or can they not be added?
Old Sep 14, 2001 | 03:01 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Double hump 461/462 heads (adam)
i have a couple of sets of those heads i used to run i drilled and tapped them for accessorys the only problem i had was the outside hole towards the top of the head its right where the head starts to curve..but other then that they worked out great.
