Lets talk compression
Old Sep 30, 2006 | 10:13 AM
Taijutsu's Avatar
Taijutsu
My advice would be drive the car untill you know what you want. More cam than you need will just blow off low end.
Why not get some good heads and 1.6 RRs for now. You will get more power, cooler running. When you know more about your driving habits, you can buy a cam to match. JMHO
Rick
Old Sep 30, 2006 | 10:31 AM
Chilli's Avatar
Chilli
Originally Posted by Scott Marzahl
The L-82 will work best with at least 9.75:1, preferably with 10:1. The L-82 has 224 degrees of duration, around .450" of lift.
Damn, I didn't think a cam that mild would need anywhere near 9.75:1 compression. Looks like I've got some homework to do.
- Chilli
Old Sep 30, 2006 | 10:52 AM
Scott Marzahl's Avatar
Scott Marzahl
The reason these GM performance cams need a higher SCR to perform decent is because they all have relatively late closing inlet valves which result in a lower DCR.
