Body Mount Removal
Old Sep 28, 2006 | 11:36 PM
edm4864's Avatar
edm4864
Cruising
Default Body Mount Removal
While trying to remove the #4 body mounts on both sides of the body, I heard the dreadful sound of the bolts spinning inside the frame. How do I access these to replace them? I searched the forums and noted how I could reach them from inside the car..no luck. And others spoke of replacing the "bird cage"..what is this? Thanks in advance..my frame off project has been delayed somewhat.
Eric
Old Sep 28, 2006 | 11:57 PM
chris73cpe's Avatar
chris73cpe
if you have a coupe, pull the rear carpet back and you can get to the nuts and (now loose) cages way in the back to hopefully get a wrench on them. If they were as bad as mine, you're much better off just grinding off the head and pulling them through from the inside.
If you have a convertible the job is a lot harder because of the deck hinge being in the way, but I'm sure someone else will be able to tell you a lot more about that.
and the birdcage is the steel frame around the cabin that includes the windshield frame, rocker channels, and roof pillars. can be a major project to repair and even worse to replace, but not impossibe. if you search through the archives you can find plenty of pictures of it that will make it a lot more clear.
Old Sep 29, 2006 | 03:34 AM
82MDVette's Avatar
82MDVette
chris73cpe is right
When the body mount bolt are rust seized, especially the #4 mount due to it constant exposure to the road grime from the rear tires), you will not get it off! Use a disc grinder and cut the head of the bolt off being careful not to destroy your #4 mounting cage.
Mine were the same situation when I started my frame-off. I powder coated my metal cages to prevent further rusting and used anti-seize on ALL of the bolts.
GOOD LUCK!
Old Sep 29, 2006 | 07:33 AM
chris73cpe's Avatar
chris73cpe
I didn't even put the cages back in, I just welded a square nut to an 1/8" piece of steel cut to fit in the well, then painted the whole thing. I wish I took some pictures of it, but I know it won't rust at all anytime soon. Definitely use stainless bolts when you put it back on too. The extra few bucks now will save you tons of grief down the road.
Old Sep 29, 2006 | 08:39 AM
jester4's Avatar
jester4
I just finished taking the #4 Bolts out of my '78, and they were seized pretty bad. I had to grind the head off the bolts from the wheel well and pull the bolts thru the top. As already stated, not a lot of room inside the mounting cage to grind, so be careful and take your time. Wear a mask and have fun
Old Sep 29, 2006 | 10:06 AM
edm4864's Avatar
edm4864
Cruising
In reference to accessing the bolts from inside on a 71' coupe, I have pulled out the carpet as it was being replaced anyway. I have checked the back corners of the car and cannot find the access point to the bolts. Is there another panel I need to pull out? I tried to attach pictures, but was unsuccessful.
Eric
Old Sep 29, 2006 | 10:12 AM
71rdster's Avatar
71rdster
I did basically the same thing on my 71 vert, used 1/4" aluminum plate. Drilled and tapped. You can't see it with the deck hinges in place
Old Sep 29, 2006 | 12:04 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Eric
They're deep in those open spaces that run beside the rear bulkhead.
Old Sep 29, 2006 | 12:13 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Hope this helps:
I installed the bolts for the rear body mounts upside down with the nut at the bottom, made it a little easier to install...
Then nut is behind the rear speakers:
Old Sep 29, 2006 | 12:44 PM
jaki30's Avatar
jaki30
Default The nut floats for a reason.
The nut(s) float so there is some adjustment for the body. The fore/aft and left/right centering of the body on the frame is why the float is needed. I wound up having to loosen all the mounts on my 72 to get the bumper brackets front and rear to align properly. There isn't a lot of movement but enough to mess things up.
Old Sep 29, 2006 | 01:06 PM
Red 69's Avatar
Red 69
Eric
On a 71 coupe you will not be able to see down into the well in which the #4 nuts and cage are located. Get yourself a hand mirror and you will be able to see down into the well and what you are after. You can see the top of the well opening in the right and left corners a few inches in front of the rear light panel. You will also need a good flashlight to reflect light off the mirror to illuminate the bottom.. The cage and nut will be toast, so as already stated, just cut them and discard. If you are replacing your body mounts, you can recycle a heavy washers to go under the nut or bolt head, depending on which way you decide to orient the mounting bolt in the well. You can also use a square washer, or anything to support under the bolt/nut in the well. Use a lock washer or nylock nut to finish the job. Below is a picture of mine after fabing a top cover for the well. It has a 2 inch inspection hole in the top. If doing it over, I'd just make a flat plate. At the time i was trying to duplicate what looked original.
[IMG][/IMG]
This is what the finished #4 nut looks like inside my finished 69 well.
[IMG][/IMG]
[IMG][/IMG]
Old Sep 29, 2006 | 02:06 PM
edm4864's Avatar
edm4864
Cruising
Everyone..thanks for your assistance!
Eric
Old Sep 29, 2006 | 10:17 PM
chris73cpe's Avatar
chris73cpe
The plate itself is still just sitting in the well, but is big enough that it can't move more than 1/4" in any direction and definitely can't spin at all. Anything is an improvement over those thin sheet metal cages they used.
Old Sep 30, 2006 | 11:02 AM
Scott Marzahl's Avatar
Scott Marzahl
Default Need bolt hole location for #4 mount plate
Does anyone have access to their #4 body mount bolt to give me a good dimension from the frame to the center of the bolt. I had to weld on a new top plate to the #4 mount due to rust damage. I believe the hole diameter for the rubber mount is 1.20" but I need the distance from the frame to locate it.
Thanks.
To Body Mount Removal
