erratic timing mark
Old Sep 29, 2006 | 06:40 PM
Lee H's Avatar
Lee H
Default erratic timing mark
Hi guys, What causes a timing mark to be erratic? I have a fresh motor, new MSD A6L box and MSD pro billet tach drive dist. At and idle or 2500 the mark is jumping around. Thanks for the advice. Lee
Old Sep 29, 2006 | 07:28 PM
jackson's Avatar
jackson
Most likely cause is bad harmonic damper ... rubber bad ... outer ring (with mark) is slipping in relation to inner hub (keyed to crank). Other possibilities: wore out timing set, worn dist gear, sheared dist gear roll pin.
Old Sep 29, 2006 | 07:38 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Mine does that!!!!
Figured it was the inductive pickup on the timing light. Usually have to move it around to get a signal
Old Sep 29, 2006 | 08:39 PM
Lee H's Avatar
Lee H
Jack, Thanks for the feed back. I'm checking and trying to eliminate possible causes. Motor has new balancer, dist gear, timing set. I'll pull the dist and check the roll pin. Again, thanks. Lee
Old Sep 29, 2006 | 10:11 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
how eratic???/ could be the gear on the bottom of the dist needs to be shimmed that will acount for 2-4* of fluctuations
Old Sep 29, 2006 | 10:52 PM
vettepilot68's Avatar
vettepilot68
Is your vac adv plugged in to the port side or the manifold side of the carb? I ask because if the answer is manifold, there is a possibility the vac can is not coming all the way in for one reason or another.
Old Sep 29, 2006 | 11:04 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Some inductive lights don't work well with MSD boxes.
Snap-On and Craftsman dial back types are two that do.
Old Sep 30, 2006 | 02:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My vote is on a separated damper.
Old Sep 30, 2006 | 05:06 AM
jotto's Avatar
jotto
Work with the simple stuff first. If all is new on engine then hopefully not your new harmonic balancer....unlikely, but not unheard of.
Check your timing light specifications and on another vehicle with a similar ignition setup.
Old Sep 30, 2006 | 07:46 AM
GDaina's Avatar
GDaina
Vacuum leak?
Old Sep 30, 2006 | 08:47 AM
Lee H's Avatar
Lee H
Thanks all. I will double check all of these things. Even though all of these things are new with a fresh engine it could be any one of these things.
I'm using a Innova timing light. First thing I will do is check timing with a stock number 1 wire VS the MSDs on it now. This timing light works great on all my other cars.
Old Sep 30, 2006 | 10:33 AM
stingr69's Avatar
stingr69
It's the MSD. MULTIPLE SPARK discharge at low RPM. You may need a different timing light to work with that MSD.
It is better to set the timing at the top of the curve anyway. You only have time for 1 spark at that point.
-Mark.
Old Sep 30, 2006 | 01:50 PM
vettepilot68
Originally Posted by GDaina
Vacuum leak?
My short reply might have been confusing...here is a quote from lars paper on vac adv. This is my point:
"...A tuning note on this: If you choose to run straight manifold vacuum to your vacuum advance in order to gain the
additional timing advance at idle, you must select a vacuum advance control unit that pulls in all of the advance at a
vacuum level 2" below (numerically less than) the manifold vacuum present at idle. If the vacuum advance control
unit is not fully pulled in at idle, it will be somewhere in its mid-range, and it will fluctuate and vary the timing
while the engine is idling.
This will cause erratic timing with associated unstable idle rpm...."
To erratic timing mark
