1969 Corvette Key Warning Buzzer Location?
Old Oct 1, 2006 | 11:35 AM
genuine1980's Avatar
genuine1980
Default 1969 Corvette Key Warning Buzzer Location?
I have a 1969 L71. The previous owner had a bad habbit of disconnecting various features...(I found the Cluch Petal Starter Switch with a jumper wire, rear astro vent vacum acutator disconnected, etc). I've recently learned that this car came with a key warming buzzer. The buzzer never worked since I owned the car, so I am wondering if it simply discconnected, but I have no idea of the location. Someone said to check the horn harness, but I have no clue where that is either. Can someone tell me exactly where to look to see if the buzzer is disconnected and other places and things I could check to see if it works?
Old Oct 1, 2006 | 11:39 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
The buzzer itself is within the horn relay, under the hood.
Check for a cut or disconnected wire coming out of the base of the steering column. I don't have a diagram here. Look in the Assembly Manual. Mine was disconnected too when I bought my 69.
Why? The plastic switch was broken within the column, and the thing buzzed constantly till I fixed it. Chuck
Old Oct 1, 2006 | 12:06 PM
Jim Shea's Avatar
Jim Shea
This is a scan that might help in your diagnosis of the problem.
http://jimshea.corvettefaq.com/wp-co...rDiagnosis.doc
Hope that it helps,
Jim
Old Oct 1, 2006 | 12:34 PM
genuine1980
Default Ahhh.. found it
It was disconnected... I reconnected it and it seems works. Sticks a little, but it does shut off when you close the door and start the car.
NICE! Thanks for the help... Chuck
And thank for the diagram Jim... i'll use that when I ty to fix the sticking.
To 1969 Corvette Key Warning Buzzer Location?
