1982 Collector Edition
Old Oct 2, 2006 | 08:07 PM
jsquatrito's Avatar
jsquatrito
4th Gear
Default 1982 Collector Edition
I have an '82 Collector Edition with the cross-fire injection engine. The engine is running rough -- instead of continuously feeding fuel, the TBI's are operating in a pattern where fuel is sprayed for about 1/2 second, then the fuel stops for 1/2 second and the cycle continues causing the engine to run poorly at best. I am trying to check for ECM fault codes to see if that is part of the problem, but I am unable to find the diagnostic link on this car. Does anyone know where it is?? Also, I would appreciate any thoughts on what could be causing this intermittent operation of the TBI's.
Jim
Old Oct 2, 2006 | 08:13 PM
wombvette's Avatar
wombvette
Link is under the ash tray.
Old Oct 2, 2006 | 08:39 PM
jsquatrito's Avatar
jsquatrito
4th Gear
Thanks!!
Old Oct 2, 2006 | 09:07 PM
jsquatrito's Avatar
jsquatrito
4th Gear
Default Fault Code 22
The ECM has a fault code of 22. Does anyone know how to address this issue? Also, is there any connection between this fault code and the rough running engine??
Jim
To 1982 Collector Edition
