Finally ordered my seat covers today after almost a year of procrastination.....
In talking to the Willcox guy, he said I could leave the seats in while removing/replacing the seat covers... Any thoughts on this or suggestions appreciated.
Followup question - do I need to remove the seats to install a new radio? (remove instrument console etc)
Heck, even I’m confused now.. What type of cover did you order? I think there might be some confusion but I'll answer this when I know what cover you bought. Then I can tell you how to do it…
You don't to take the seat frame out the the foam pieces you have
to take out. To get the center console cover out it is easier to take
the seat frame out to get at the carpeting screws. I took my radio
out thru right side and that seat is help by for nuts from top side.
Nuts or Bolts, can't remember.
Pulling the seats has a couple advantages, you ca completely clean and paint the buckets, clean and lube the rails, clean the carpet and fix up the side panels on the console while your at itNew Seat Covers call for makin it look like new
I ordered the mounted "driver leather" seat covers from Willcox...
And if I need to or should take the seats out, I figure I should do the radio at the same time.... otherwise I can hold off on the radio for while (it works but the display is screwy!)
Now I am confused: What the heck does the radio have to do with the seats? In the '81, and I am guessing any C3 the radio is in the upper center console area, and comes out with removing 4 screws, and disconnecting the harness, and a couple of other wire connections. You will have the center console piece in your hand, and ready for the radio change. The question then becomes do you cut your exsistng console piece to install an aftermarket radio, buy a "look a like radio" with some of the modern capabilities, or do you buy an already cut piece, and save the original?
The seats should be removed as stated above, so you can clean & repaint the old frames & plastic pieces to make the job look really good. You could probably remove the foam pieces and do the job in the car, but removing the seats is very easy, 4 bolts each.
Steve, I did this job two weeks ago with the seats out. I needed to repair my seat buckets and paint them anyway. Both of my seats are held down by 4 bolts and I bet I could remove and re-install both in less then 30 min. When I went to install my new leather covered foam it was a little more difficult than I thought it would be. It sure looks simple enough, four clips on each bucket to attach the foam. Well it turns out it's one of those "not as easy as it looks" deals. I got mine on after I stopped trying to be delicate with the foam. I also took a couple pairs of pliers and put a little joggle in the wire on the seat foam in the area of the attach point. The joggle made the wire stick out of the foam a little and was a BIG help. I got the idea for the joggle from this forum of course. So if it was me Steve I'd take the seats out to install your new covered foam. It'll be a lot easier to use your body weight while trying to get the wire to grab the clips. I'm sure you'll get it on either way. I'm 6"4" and needed the extra room out of the car to wrestle with them. Good Luck, Augie
You're right, it doesn't seem strictly necessary (or intuitive)
Augie, thanks for your opinion removing the seats, I think I will do so. Did you have any trouble at all with the process (maybe alignment) that I should watch out for?
From what I read, the process is simply: remove front nuts, slide seat forward, remove rear nuts, tip seat to remove wiring, remove seat. Seems too easy
Steve, mine were that simple. Four bolts and the wire (I forgot them). I bet I could take them out quicker than the wife can paint her nails. You can't screw up the alignment either. After seeing how easy they come out I can see me taking them out in the future for any work under the dash or God forbid I have to do the heater core again. Hope I didn't just jinx myself.
Mine didn't have any lower console screws that attached anywhere. I would try the 4 screws first, and see how it goes. You definately want to disconnect the battery, as it is very easy to short something in the dash, I speak from experience, bad experience!
Hi Gary, I am a bit unclear which 4 screws you mean, do mean the four that are around the radio itself? Can you please clarify?
I *am* goiing to have someone else do it, but I want to give them instructions (like disconnecting the battery!)
Related question - will "standard" 4x6 and 6x9 speakers fit OK? If so, I can get those put in at the same time.....
I installed new seat covers in my vette. I bought them with new foam. All you have to do is slide the metal strip on the seat cover over the metal clip on the fiberglass seat. I had to remove some extra foam on the seat so the metal strip could clear the metal retaining clip on the seat.
The radio is a little easier with the seats out because you can remove the side panels totally, otherwise you bend them out of the way.
i just covered mine on tuesday wih 100% leather seat covers out of the corvette america book, i took the seat out, taking the seat out is really easy you just have to slide the seat back, take the front 2 bols out, then slide it forward and take the back 2 out. mines a 74 so i dont know if yours is different but the process took 3-4 hours
Thanks all for your help
In the top portion of the center console, the part with the radio and gauges there are 4 screws, 2 on the top, and 1 on each side about 1/2 up the console. Remove those 4 screws, and see if the console pulls out. It is a little difficult because the radio, lamp on the top of the console, and your gauge power connector are attached. Mine came out just by removing these. If there are other screws that attach the console, they were not there on mine. Just be careful that you don't over stress anything when you are removing.
If in fact you do have to remove the side panels of the lower console, you will need to remove your seats, which is a 10 minute job, no big deal. I think that you will find that anytime you need to work on something under the dash, it is easy enogh ot remove the seat to give yourself more room.
The dash speakers are a bit smaller than 4X6, I think they were something like 3X5. I bought Pioneers, as they were what I could find locally to fit (Best Buy store). The 6X9 fit in the rear, although I had to work a little to get them in place as the magnets on the back of the upgraded speaker are quite a bit larger than the stock Delco's.
