Brake Problems on 82
Old Oct 3, 2006 | 04:11 PM
jgvette82's Avatar
jgvette82
8th Gear
Default Brake Problems on 82
I pulled the brakes off of the front and found that there was leakage in two of the pistons. One piston came off easy, while the other three aren't budging. Any suggestions on how to get the pistons out?
Jeff
Old Oct 3, 2006 | 04:14 PM
Twin_Turbo's Avatar
Twin_Turbo
hook the caliper up to compressed air, they'll shoot out.
Old Oct 3, 2006 | 04:29 PM
Duke94's Avatar
Duke94
You'll need to C-clamp a plate loosely over each set of pistons and blow them out (air hose) a little at a time. If you don't, after the first one comes out, you won't have any pressure left in the caliper. If they are rusted up, just leave them alone and buy new ones with SS sleeves and O'ring seals.
Old Oct 3, 2006 | 04:37 PM
jgvette82's Avatar
jgvette82
8th Gear
Thanks a bunch. They are all out now. No wonder the brakes didn't work well, there was soooooo much crap in the fluid.
To Brake Problems on 82
