c5 brakes on C3?
Old Oct 4, 2006 | 03:09 PM
Swaps's Avatar
Swaps
Default c5 brakes on C3?
is it possible?
what kind of work would need to be done for this conversion?
Old Oct 4, 2006 | 03:47 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, 70LS1 has done it, lotsa work and the C5 calipers are floating, you need to have the hubs machined and all...(to use the C5 rotors). You're better off with a wilwood kit from Keith (corvettengineering)
Old Oct 4, 2006 | 05:44 PM
Swaps's Avatar
Swaps
arrighty, i'll sent him a note.
thx
Old Oct 4, 2006 | 06:28 PM
70 LS1's Avatar
70 LS1
I agree, the C5's look cool and perform fine, but for ease of installation, call Keith.
Old Oct 4, 2006 | 08:58 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Originally Posted by 70 LS1
call Keith.
I'll third that.
C5 guys upgrade to wilwoods. Skip a step.
Old Oct 4, 2006 | 10:04 PM
flynhi's Avatar
flynhi
Just finished the Wilwood install with parts from Corvette Engineering. No significant problems other than bleeding took quite a while.
Improvement in braking is significant.
Old Oct 4, 2006 | 11:55 PM
Ray Y's Avatar
Ray Y
I like your result description. I should go to the Wildwood site but I'm being lazy....what kit did you use on what? I need a winter project. Winters in Montana are LOOOONG.
Old Oct 5, 2006 | 08:28 AM
flynhi's Avatar
flynhi
I used Corvette Engineering's Talledega (front) and Blackhawk (rear) kits with Wilwood BP-10 pads. These are forged calipers with pads with high coefficient of friction at low temp (don't require warm up to perform well).
I also used Raybestos BruteStop drilled and slotted rotors from AutoParts America and RockAuto. Total cost for parts - about $1300.
I haven't done a panic stop to determine 60-0 performance but seat of the pants tells me it is considerably better than my OE setup which wasn't at all bad.
Old Oct 6, 2006 | 09:25 PM
Ray Y's Avatar
Ray Y
Thanks for the details. I'll do my homework.
To c5 brakes on C3?
