Carter vs Rochester
I'll keep it simple, though.
The carter afb was designed in like the 50's I believe and was like a 450 or so cfm carburetor at first. It was eventually enlarged to flow more cfm but it wasn't very big at first. It was pretty simple and most people understand how they work.
The rochester carburetors (q-jet, dualjet, and fomg the monojet!) were designed, initially, in the 60's and are much more precise in fuel metering. The basic goodies, that the q-jet has over the carter, are that it's essentially a variable cfm carburetor (they were used on V6s up to 500ci caddy engines and big chrysler engines), they come in 3 sizes 750, 795, and 850 cfm (large, XL, and XXL basically), and they work a hell of a long time without needing to be tinkered with. They're probably the least understood of any carburetor but are one of the most efficient, once tuned. Their efficiency is only surpassed by later carburetors such as Weber, Mikuni, and CVK. The second two are mainly used on motorcycles now, while weber is mainly a racecar or custom application carb.
Both carburetors do their job of mixing fuel with air and shoving it in the engine, but the quadrajet requires more fine tuning to get it running good. Basically simplicity vs. complexity but neither are really very complex at all.
Many hate the q-jet and many love it (I know I do
Carter built Quadrajets for GM well after 1969... at least up to 1973
All 1970 Corvettes came from the factory with either the Quadrajet or a Holley
Carter Quadrajets are no different then the Rochester
If you have something other than the Carter QJ or the Holley then I would think about a swap.
Can you post the stamped number of your carb?
And above the QuadraJet cast: MDF.BY
CARTER
CARBURETOR
FOR GMC
CARTER
CARBURETOR
FOR GMC
I suggest you keep your paws on that one
What transmission/engine/rear end ratio ?
Also, what are you getting for milage
I can squeeze 18 or 19 MPG at 60-65 MPH
If I play around I will be lucky to see 12 MPG
Keep in mind I have the 3.08 gears and only turn 2,700 RPM at 70 MPH
Somehow I got confused as to who the original poster was
The thread was started by Amature (thats the persons name)
Now Im very confused
Anyhow....corvald
What carb is on your engine at the present time?
Anyhow....corvald
I'm aware that Buick/Olds had the 800 QJ though?
What are the details on the 850 QJ (what was it used in, how to ID it etc)?
Agree that the Q-Jet simply the best mass produced street carb made (get 19MPG out of my 375HP 406 at cruise with 700R4 and 3.08's, and run 12.87 @ 112MPH at 330ft).
One advantage of the AFB design is that the Primary Rods can be swapped easily if you change altitude often (it's the Secondary Rods that swap easily with the QJ, which is good for the strip). I've also heard that AFB's have a problem with high G (lateral I think?), so they're likely not so good on the track (but fine on the street).
Doug
70= Rochester (or Carter built Rochester)/ 40= 1970/ 2=49 State, Not a California carb/ 0= Chevrolet and the 3 = Manual transmission
