That's right it's behind the kick panel in an inset in the side wall. If you got out #1, the rest are cake. The head of the bolts broke off on both my #4's, so be careful.
If those pics you have listed are current I am a few weekends ahead of you on my 78SA. :cool:
If you haven't picked one up yet getting the assembly manual is a good idea. I picked mine up on e-bay for around $20.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Re: body mounts - removing (Lohkay)
Those nuts have been there for 23 years and if you think they will come off easy better
think twice, like the poster above says soak them with liquid wrench for a week before
and cross your fingers.
Thanx...found the #2 bolts...didn't think to look there. They are already soaking in liquid wrench....unfortunatly I can't spray them for a week...I'll spray them every 30mins until tomorow and then I'll try them out. If I'm lucky as I've been with every bolt till now, they'll come off easy... The steering column is pratically off (just waiting for someone to be here and check in the engine bay as I pull it. meanwhile I'll make sure I took everything off....with a bit of luck my weekend picture will be of the frame only. :D
