A mechanical pump increases flow w/ rpm which is exactly what's needed.
Think about a better intake- high rise intakes fit under the med. rise 77 hood.
I have the deep style on my 1973 L-48
I wonder what the difference is other than it seems one holds more fuel
Thanks!
Your '73 is a three port pump, the other one is a two port. The third port is the 'bypass' or 'return line' which helps mimimise vapour lock by constantly circulating fuel.
Bubba and his friends frequently downgrade their cars by installing a two port pump 'cause they look nice and shiny in the Summit catalog.
Thanks guys.
My current fuel pump off my 77 is the 3 port pump, with many rust holes in the bottom.
I guess the 3 port pump will still work fine in a LT1 motor
